Anything not obvious I'm missing for audio install?
broncoToBe
Not a Bronco
Things I have:
  • Stinger subwoofer enclosure
  • AudioControl LC5.1300 with harness from plugnplay
  • 2 pairs of Kicker 47KS
  • AMP wiring kit with power cables
Is there anything else I'm gonna need? Maybe some tools to take out the plastic panels?
broncoToBe
Not a Bronco
Yes - those dash speaker grilles are very soft plastic, and their tabs are easily broken.
Got an amazon link for that? Not sure what to type for it to show up
TXBronco72
Magnolia, Tx
F250 / ‘23 BRaptor
Things I have:
i would look up a video of removing the front speaker grills. They have a plastic lip opposite side from the front windshield that will break. You want to pry around the sides and the windshield side, then pull the grill toward the windshield.
As far as what you’re missing….many people are installing 300 Hz bass blockers on the dash speakers. I installed the same speakers as you and left them off to see if I liked it. I ended up going back and installing them.
Garemlin
Delaware
I agree on checking out videos on the dash speaker grille removal. I was watching a random audio upgrade video and if you go into it blind you could break the grilles. Ford made it way harder than it needs to be.
broncoToBe
Not a Bronco
What was the difference between bass blockers and no bass blickers? Also, link to the ones you bought?
Copperhorse73
Justin
Mooresville, NC
Definitely want bass blockers. Also, MTI acoustics makes a nice bronco-specific amp mount for the passenger rear above the wheel well, makes mounting a breeze
Bschurr
NY
Things I have:
You are gonna need a fuse for the + cable that connects to the battery and some high quality 12AWG speaker cable from the amp to the sub. To help run the power wire from the amp you may need a wire hanger or some fish tape to snake through the trim panels. Lastly, get yourself some zip ties & some cloth tape to make sure all the wires are neatly managed and protected from any chafing. Good luck!
jacknifetoaswan
JR
Charleston, SC
2016 Mustang GT/PP
It's really, really easy, actually, you just need to pry with the right tool at the right place.
I uploaded this video to Youtube last week:
JR
broncoToBe
Not a Bronco
broncoToBe
Not a Bronco
I ordered this https://www.amazon.com/dp/B019Z3RCG2?ref_=cm_sw_r_apin_dp_K4V9XMGHR95VB6VSVCPH&th=1 would that include all you mentioned for the amp and sub?
cyberfalco
Tony
Conway, AR
2011 JK, 2000 Ram 2500, 1993 FZJ80, 1994 FZJ80
The signal to the rear speakers and dash speakers is already cutoff at a higher frequency so bass blockers are not necessary. Only the kick panels get full signal.
If you plan on sending full signal from the amp, then yes you should get some sort of crossover.
Billnchristy
William
Georgia
2022 Bmw m440i gc,2022 BD 2dr, 1966 mustang
That's not true for the dash. The dash speakers go through the kick panel speakers and have a capacitor built into the speaker. You do need them up front.
cyberfalco
Tony
Conway, AR
You're right, I forgot about that.
