Another leaking bronco
Monster1926
Indiana
GMC Sierra 2500HD
Agreed on the bold, I wish the A10 in my F150 had half the refinement of the A8 in my JL....
The 10r80 in your f-150 is even worse than 10r60 in the bronco. Atleast in my raptor it was horrible. Weird thing is GM and ford co-developed the trans, so essentially they’re the same. The 10 speed in my GMC is buttery smooth.
Imaginary Friend
Southern MN
A passel of Fords and a Jeep JL Rubi
Yeah, from what I've read (and experience) Ford should have hired GM's trans programmers.
TCB-1
Doug
Kansas
'23 Black Diamond, '06 Scion xB, '61 Impala
My rear main is seeping just a tablespoon over a month. In true Ford fashion, the tech just says, "It'll clear up sometime". Owned Toyotas the last 14 years and the first Ford since '93. The lack of overall quality control and Ford's "stick head in the sand on an obvious issue" just drives me nuts.
Sdracing
Chaz
Sacramento
2021 Outer Banks-Sasquatch / 2003 Cobra
I looked at a Jeep, Bronco and Defender. Defender is too unreliable to own out of warranty. I also looked at Jeeps. I went with the Bronco when I found one that was loaded. In a month, I have put 3k miles on my Bronco OBX SAS and driven it across country. I absolutely love it. I looked at Jeeps. They have issues with paint bubbling, electronic things, etc. However the biggest issue was the driving experience. The steering is loose.
When I turned the wheel, I felt like the jeep looked at the input as more of a suggestion then a command. Offloading they are awesome. But for me Broncos are superior in the interior, and a leaking seal would not be enough to buy a jeep.
Tor148
Tor
Cape May Court House, NJ
23 Braptor Bk, 21 FE RR, 15 F250,
I agree with all of this.
And my First Edition rear main seal is leaking. Stuff happens. Every vehicle has there idiosyncrasies. Should be fixed with warranty and I will move on, hopefully😁
Jace 21583
Jace 21583
Wisconsin
2021 Badlands, 2021 Ram TRX
If this were the only issue I've had so far then yeah I'd agree, not enough to get rid of it. Driveshafts already been replaced, the hood/window cowl is being replaced, one of the rear defroster connections broke off and it's being fixed, and a couple other small things almost not worth mentioning except for the fact that the closest Ford dealership is 75 minutes away, one way. Closest cdjr dealer is 12 mins away.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hello, Tor! This rear main seal concern doesn’t sound like something we want you to experience with your Bronco. If you are still needing assistance regarding this concern, I'd be more than happy to see what I can do to further help. Just shoot us a PM with your VIN and dealer name/location, and I'll get right on it. To send a private message, just click on our username and select "Start Conversation". Thank you!
Tor148
Tor
So dealer picked up on Tuesday, dropped off on Wednesday afternoon, with no call or any info. Slip in car. Went to move it tonight and guess what.
Check engine light is on!
Ford Bronco Another leaking bronco 1000025957
Ford Bronco Another leaking bronco 1000025964
Ok, so I assume a sensor is unplugged. So put it on my lift.
Cant see anything unhooked but did see this senor cable supper tight and looks like it should go in this clip
Ford Bronco Another leaking bronco 1000025961
Looks like that wire is ripping out of the sensor. On the other side the cable on the sensor looks, not right.
Ford Bronco Another leaking bronco 1000025962
So now i have to decide to I just go in the morning an drop off or call and set something up.
What really sucks is I am leading a trail ride on Saturday, was going to use her for it.
