6gtexanbronco
Charles
'22 Bronco Raptor, '74 Wagoneer, '20 Navi
Very nice. I have been planning out doing something similar.
6gtexanbronco
Charles
Do you mind sharing what hinges you used? Thanks
Trigger
Trigger
Kansas
2004 Silverado/2022 Black Diamond
I just grabbed the ones at Home Depot. I think Lowe’s carries the same brand. Seem to work well.
6gtexanbronco
Charles
Is it a piano hinge? I couldn’t tell from the photo. Thanks
Trigger
Trigger
Kansas
Yes. I think they call it a continuous hinge but I believe the same thing. Everbilt brand I think. Its key to go all the way across the platform pieces.
TheGriffin1313
Mongo
2022 Mav
I’ve been taking notes of all the others making a level platform in the 2DR without removing seats.
Plywood, 1x6, hinges, hardware, carpet and time. Folds up to put seats up and relatively easy to remove. Good platform for the dogs and decent storage.
Thought I’d share.
This was my starting point. Had to make some adjustments along the way. Had to taper the lid to clear interior trim when opened. Few others as well.
great work
jakej
Jake
2016 F150
Thought I’d share.
Very cool and really well done! Thanks for sharing, I may use this and "extend" for my 4D. Really want to be able to use The Bronco for backroad camping. Thanks for the inspiration.
gtabert
Greg
Woodstock, IL
'18 gt350r / '65 f100 / '99 Silverado / '15 VW TDI
Thought I’d share.
You did a great job on construction and engineering. Thanks for sharing and approving of others to copy, no better compliment than when one follows your example. This is one of the best out there. I plan on following the plans, it will save me a lot of money, time and effort. Be Safe
Poolboy1637
Douglas
Canandaigua, NY
15 Mustang GT
Excellent setup. I particularly like the ability to fold up without taking up most of the rear cargo area. I'll likely be shamelessly copying this design when I decide to modify my cargo area.
Arokcrwlr
Kraig
US - Alabama
2014 F150, 2014 Focus, 1973 Bronco
Looks great! I would copy your design, but I'm removing my rear seats. Since I'm not a carpenter, I have a question - is there a benefit to cutting 45s vs. just butting up the 2xs? It's not really going to visible...
Trigger
Trigger
Kansas
I am not sure if there is a ‘strength’ difference to mitre over Butt joint. Someone smarter than me would have to weigh in. I liked the looks of it. I did strengthen it with a small piece of wood glued in the corner. I did use 1x vice a 2x for the frame. I think it’ll be great and easier to move in and out.
Trigger
Trigger
Kansas
Hapa
J
Washington
Tacoma
Great setup Trigger. I am designing a similar setup. I want to add support legs adjacent to the seats near the front. Do you think there is room? I know you mentioned you put some on the middle.
Also wondering if you noticed any effects of the weight on the folded seats (squishing the seats over time) or if they seem pretty sturdy. Thank you in advance!
Trigger
Trigger
Kansas
You can probably put short legs but they would just be around 4.5". I really think just the loose piece of board (carpeted) that sits between the seats works great. It can actually stay there with the seats up and work fine. I'll see if I can get a picture of it. It's really just a scrap piece of the "box" since it needs to be the same depth. I wouldn't want to attach any legs since they would get in the way of the z-fold.
The seats still function and look great. I am still extremely pleased with the setup. It looks very clean in back and I rarely have seats up. My intent with the loose piece of wood between the seats is to carry the weight so the seats don't get compressed. I think it is working great.
Hapa
J
Washington
Tacoma
Picture would be awesome! I assume you formed a "T" shape to keep it stable for the piece between the seats?
My idea was for the side supports is to have 2 pieces of 1x or 3/4" ply and use these (or similar) furniture feet to contact the floor. Sadly this is all on paper until I actually have my bronco delivered but I figure I can build it before hand. I am worried about "squishing" the seats because most of the time, like you, I will have the seats down.
I wasn't sure if the side supports would fit between the sidewalls and the seats. To me it doesn't seem like a lot of space. But I see you were able to snake a piece in the center, which also looks tight.
https://www.rockler.com/heavy-duty-...anCNOxA4EQEktTQGm4GwWHD-v0ntpmoIaAgoUEALw_wcB
