Airmoto Mini Air Pump
swooshdave
Portland, Oregon
Mustang
I searched and didn't find anything. Not sure if there is something compatible that people are using instead. I was looking for something compact for very occasional use. Not sure if this would pump the tires up from say 20psi to 30-something (x4 times).
https://getairmoto.com/
Ford Bronco Airmoto Mini Air Pump step3
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Ehhhhhh maybe. But it's going to take you about 5+ minutes per tire. That thing is VERY VERY week and VERY VERY slow.
swooshdave
swooshdave
Portland, Oregon
Mustang
I need to look at what other handheld options there are.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Honestly any handheld option is going to be junk for the most part when it comes to an SUV/Truck. They are very tiny for a reason... because they lack power.
If you don't want to spend the money on a full blown ARB System (https://www.4x4truckleds.com/kr-off-road-arb-compressor-engine-bay-mount-for-2021-ford-bronco/)
You can get something cheaper in the $240 range. I ran the ViAIR 400P for over 17 years in my personal truck. Still have it to this day (although I have an ARB now in all my trucks, the ViAIR still works). It's portable, inexpensive and will do the job:
https://www.4x4truckleds.com/air-compressors/
JeffROK
South Korea
2022 Outer Banks
Did you use the Viair 400p on 35" tires?
Ground_zero298
Scs michigan
mcinfantry
Lee
Louisiana
Badlands 2 door
4x4TruckLEDs.com
Adam
Lindenhurst, NY
