AIGMUX New Year Offers
linda_aig
Lux Sponsor (Level 2)
Montgomery
bronco outer banks
25% off for four-door built-in ceiling reading lights, click the link to enjoy it now.
Link: https://www.amazon.com/dp/B0DK2WC6BM?th=1
Appearance: The rear ceiling light is customized according to the original car data and is perfectly compatible with 2021 2022 2023 2024 2025. This ceiling light is only suitable for Bronco 4-door models, compatible with Ford 4-door models, we will upgrade your interior lights.
Function: This upgraded ceiling light will provide bright lighting, improve visibility in the car, and easily illuminate all areas from the front seats to the trunk cargo area. Compared with traditional reading lights, the angle is wider. Whether it is reading, finding things, putting on makeup, eating snacks, or children playing with toys, it is more convenient.
Installation: No drilling required, no damage to the vehicle. Simply remove the original light fixture (including adhesive fastened to the rear roll bar).
Operation: The operation is very simple, just touch the switch with your finger to turn on and off the ceiling light and adjust the brightness. Bring you a convenient and worry-free experience.
10% off on Bronco-specific driver-side cup holder, click the link to enjoy it now.
Link: https://www.amazon.com/dp/B0DK3BXGKQ
Appearance: You will enjoy the extra space to store cups and drinks (up to 30 oz size), and even other small items. Perfectly compatible with Ford Bronco accessories!
Function: Suitable for 2021-2024 Ford Bronco. Please check if your model is suitable before purchasing. Note: This product is only suitable for the driver's side, not for the co-pilot side.
Installation: The bite design of the cup holder can get a stronger grip and is not easy to slip or vibrate. It has a strong grip in places where it does not move. No need to worry about it falling out.
Material: ABS plastic, the cup holder will not bounce, slip or fall off even when driving on rough roads.
10% off for Raptor style taillights, send "I want"
I will send you an exclusive discount code
Link: https://www.amazon.com/dp/B0DJ48FVZ6
Appearance: Ford Mustang 2021 2022 2023 20242025 LED taillights, 2-door and 4-door versions, full LED taillight replacement parts make your car look more unique.
Function: It uses full LED light source instead of traditional halogen lamps, LED light guide plate, LED turn signal, LED brake light, LED reverse light, 3D dynamic effect is very good, making your car look cooler and sexier on the road, it updates the appearance of your car and brings a unique style to your car.
Installation: Plug and play, no wiring or any modification is required. According to the original car design, it can be directly replaced. This taillight uses an adapter cable for adjustment, and the installation time is usually short and does not require much effort.
Material: Made of ABS plastic, it has good heat resistance, impact resistance, electroplating, coating, dimensional stability, and is suitable for any environment and climate.
We will continue to develop and manufacture products. If you have any good ideas and suggestions, please leave me a message, or join the AIGMUX community to learn about the latest product releases, exclusive promotional discounts, and abundant free product application opportunities.
AZ_Craig
Craig
Mesa, AZ
2024 Ford Bronco Raptor, 2023 Kia EV6 GT
Anyone get their new interior light yet? Worth it?
Ninjak
Miami
I have it, I like it. Gives good light, and it matches up well with the LED drop-handle lights I have.
linda_aig
linda_aig
Montgomery
bronco outer banks
Tried this out since it was on sale
It does put off more light, and it was very easy to install
But it’s not a lot more light — this would be a great $20 upgrade but even at this sale price I don’t feel I got a good deal
The touch sensitive button on it is maddening. If anyone hits it, you have to turn off the dome lights from the front console, then turn off the dome light with the touch switch, then turn the master dome light switch back up front on. The fact that it’s a touch button and not a toggle switch makes it very difficult to figure that out.
