Aftermarket wheel options.
Cptjockitch
william
Tampa florida
2012 ford raptor
VegasKoop
Las Vegas
Lincoln MKS
So I was just looking for aftermarket wheel options for the bronco and seems like Fifteen52 has a few options and 17x8.5 with the 6x139.7 lug and 0 offset. 106.2 centerbore seems to be the right size to look for. I’ve always like the Japanese wheels and Kansei makes a truck wheel that seems perfect for the bronco.
https://kanseiwheels.com/products/kansei-knp-truck-black?variant=32170148102227 . https://fifteen52.com/collections/ford-bronco-wheels .
Hmmm. None of those will work for me but they look good.
Raptor911
Raptor911
Broadlands, VA
how do you know the bronco has a 106.2 center bore?
I will give a hint that it not. The 4runner and Tacoma specs are below so the specs you are looking is for a Toyota truck.
Bolt Pattern: 6x5.5 / 6x139.7
Center bore: 106.1 mm (hub-centric for Toyota trucks)
KH_59
Kevin
pearland tx 77584
F-150
Bronco wheel center bore is probably 93.1mm (like the Ranger).
Why go with zero offset?
69351windsor
JW
69 Merc, Ranger, HD
Would have to assume that before long there will be a lot of great aftermarket wheels specifically for the Bronco. Might even be some now.
broadicustomworks
Hanging Rock, North Carolina
I certainly hope the 106.2 CB works, as I have 5 of the Fifteen52 Traverse sitting in the shop for it, and it's what Discount Tire brought up on their system as fitment.
zero offset gives you a bit of a deeper profile, just enough to look good.
Same wheels that are on the Overland BL, Traverse with the 0 offset. And they looked GOOD on it.
KH_59
Kevin
pearland tx 77584
F-150
broadicustomworks
Tonka Bronka
Duncansville
F350, V60 Polestar, 900SS, K1300S, RnineT Racer
That would be a very safe assumption. This party is just getting warmed up!
Cptjockitch
william
Tampa florida
2012 ford raptor
I’m looking at the ford bronco page in the fifteen52 website.
center bore size really doesn’t matter. If the bronco does have a smaller bore then these wheels should fit. You can always get a bore ring to make up the difference. 6x139.7 does seem to be right everywhere I look. The 0 offset isn’t set in stone. They also have -10 offset for these wheels.
Raptor911
Raptor911
Broadlands, VA
what you talking about Willis >> center bore size really doesn’t matter.
Why is every oem wheel the correct center bore then?
pan-y-cerveza
Manitoba
Tacoma Pro
Alright! Another centre bore and hub-centric rings discussion!
Cptjockitch
william
Tampa florida
2012 ford raptor
Most aftermarket wheel manufacturers make the center bore larger so that it can fit more vehicles. You can always use a center bore ring to make up the difference. Should a wheel with a larger center bore stop someone from buying it?
Raptor911
Raptor911
Broadlands, VA
you never answered my question. Why do Oem wheels have the correct center bore size?
btw ... wheels companies that make wheels to fit multiple cars are taking a short cut.
a reputable wheel company will make wheels specific to one car.
I run Titan7s on my 2019 Raptor. Every wheel is machined exactly to the center bore for every application.
https://titan-7.com/
