AFE Bronco Exhaust Options!
Mitch Panda Motorworks
Mitch
St. Louis, MO
www.pandamotorworks.com
2021 Ford Bronco, 2014 Fiesta ST
If you are looking for a new exhaust for your Bronco, AFE dropped a few different options for you! AFE provides you with a great system at a great price! Check out all the Options Below!
Apollo GT Series Hi-Tuck 3in 409ss Cat-Back Exhaust System
Ford Bronco AFE Bronco Exhaust Options! 49-43135_1_1.1635369358
This 3" exhaust
uses mandrel bent 409 stainless steel tubing and a high-flow stainless steel muffler to produce a deep tone. The High tuck design protects the cat-back and gives you additional ground clearance all while utilizing factory mounting locations. This system is designed to fit both 2-door and 4-door models!
Apollo GT Series 3in 409 Stainless Steel Cat-Back
Ford Bronco AFE Bronco Exhaust Options! 49-43136-b_1.1633703125
Ford Bronco AFE Bronco Exhaust Options! 49-43136-p_1.1633703170
Much like the Apollo GT Hi-Tuck, this system uses mandrel bent 409 stainless steel tubing but has 2 high-flow stainless steel mufflers to produce a a more mild tone. This system features a single, angled 4" tip with in your choice of Black or Polished Silver. This system was designed to fit both 2-door and 4-door models!
Vulcan Series 3" - 2.5" 304ss Axle Back System
Ford Bronco AFE Bronco Exhaust Options! 49-33137-b_1.1634162105
Ford Bronco AFE Bronco Exhaust Options! 49-33137-c_1.1634162217
Ford Bronco AFE Bronco Exhaust Options! 49-33137-p_1.1634162227
This axle-back exhaust system uses 3" mandrel bent 304 Stainless Steel tubing that mates perfectly to the factory mid-pipe. This is a dual tip system that provides an aggressive, street-style look for your Bronco with your choice of Black, Carbon Fiber, or Polished Silver tips! The result is a mild tone.
Vulcan Series 3" - 2.5" 304ss Cat Back System
Ford Bronco AFE Bronco Exhaust Options! 49-33138-b_1_2.1636658285
Ford Bronco AFE Bronco Exhaust Options! 49-33138-c_1_1.1636669924
Ford Bronco AFE Bronco Exhaust Options! 49-33138-p_1_1.1635373254
This cat back exhaust system utilizes the axle back system outlined above, but adds the mid pipe section to make this a true cat back. The mid-pipe section adds a 2nd high flow muffler with mandrel bent 3" tubing. This system mates perfectly to the OEM downpipe and uses all factory mounting points.
if you are looking to upgrade your exhaust, you should consider an AFE system, or one of the many other exhaust systems we offer at pandamotorworks.com!
Penco
Juan
Miami
Are you guys developing a hi-flow cat or cat-less downpipe?
Interested in running a hi-flow cat with stock exhaust.
Ground_zero298
Scs michigan
Love my zero fucks given. Great for messing with people.
JoeSpeed
Eatontown, Jersey
2dr 2.3 Manual
Ditto, not into catbacks on 4bangers, but do wanna downpipe
Mitch
St. Louis, MO
Nothing in the works as of now. We will keep you posted if anything changes!
