Adding a 7 pin factory wiring harness
Texasliam
Liam
I'm getting mine built without a towing package. Has anyone had the 7 pin factory wiring harness installed after delivery, so that it integrates with existing electronics. I'm trying to avoid an aftermarket break controller. Tell me the details please.
RagnarKon
Ford Bronco, Escape, Focus
TroutTrooper
James
2014 Fiesta ST, 2001 Jeep Wrangler, 1988 Ranger (SVO swap), 1974 Super Beetle
So Lumen just released a 7-pin tow harness kit 2-3 months ago, and it is sold via Ford Accessories. No personal experience with it, but I read the instructions and it seems to a near-factory-like replacement as it plugs into the same harnesses in the same locations that the factory tow module uses.
https://accessories.ford.com/products/trailer-hitch-wiring-harness-4-7-pin-by-lumen
I ordered the Lumen kit last month. So far all Ford has sent me is a few emails telling me it's on backorder.
jd-ford-hd
Tennessee
‘16 Explorer, ‘13 F150, ‘99 F350, '74 Bronco
jd-ford-hd
Tennessee
Go to this thread and scroll down to post #23 where I laid it out for you. Even with tow package from the factory there is not a brake controller, only the 7 pin plug and receiver hitch. This Redarc brake controller is what you receive when you order from Ford accessories.
FORD ACCESSORY BRAKE CONTROLLER INSTALL MADE EASY.! | Page 2 | Bronco6G - 2021+ Ford Bronco & Bronco Raptor Forum, News, Blog & Owners Community
BroncRider
22 BaseSquatch 2dr
I ordered mine a week ago and it arrived 3 days ago 🤷‍♂️.Working on the installation today.
I had the ford 4-pin harness on order but had waited a month and it was still back ordered. Saw this 4/7 pin from lumen was out so switched my order over. Guess I got lucky.
TroutTrooper
James
Ford Bronco Adding a 7 pin factory wiring harness that70s-show-oh-is-that-what-were-gonna-do-today
BroncRider
22 BaseSquatch 2dr
Install is done. It was a bit of a pain, but it is a nice clean install. The instructions leave a little to be desired, had to do a lot of head scratching.
The worst part was the wire harness doesn’t have the right terminals to fit the existing plug. I toyed with it for an hour and a half before remembering there splices and 4” wire pieces in the box. These do have the correct ends so you have to cut and splice the harness… this was not in the instructions.
Hooked it up the trailer and everything works. Odd part is that the instructions state you have to get into FDRS and activate the trailer setting. I did not do that and it works, not sure why, but I’m not complaining.
Ford Bronco Adding a 7 pin factory wiring harness image
BkCntryCrwlr
SW Idaho
F250 King Ranch
So, BroncRider, what did you do for the trailer brake controller? It doesn't show this in the kit from Ford? Did you buy a Redarc seperately and install it? If so where did you plug it in?
Thanks
AlpineFisher
Seattle
1971 Bronco
I'm going to tackle this install over the weekend. As you said, the instructions are definitely lacking. Can you share anymore about the splicing you had to do? Any tips to help reduce the head scratching coming my way would be greatly appreciated!!
Philyn8iv
Summerville SC
Bronco, Edge, Mitsubishi 3000GT
The Ford accessories website has 20% off orders of $300 or more (Summer20) if you select dealer install it’s puts it over that threshold. I’ve attached screenshots. Also remember if the dealer installs it then it’s covered by the warranty. Well worth not having to put up with the aggravation. I’m scheduling for next Friday.
Ford Bronco Adding a 7 pin factory wiring harness IMG_9472
Ford Bronco Adding a 7 pin factory wiring harness IMG_9474
BroncRider
22 BaseSquatch 2dr
Thanks
I haven’t added a brake controller yet. Will probably go with Redarc when the time comes.
BroncRider
22 BaseSquatch 2dr
The splicing was to change the wire pins to fit the plug under the driver’s side panel. It wasn’t hard, just another thing to add time to the project. I did use my own posilock splicers as the included ones weren’t the best.
Tips: taking fender liners off and reinstalling was annoyingly time consuming, get new plastic clips ahead of time. Lifting the drivers side to let the tire droop added a lot of good working space. After wrestling with the plugs under the driver’s fender, I cut the zip ties and pulled them out for better access to install wires.
