Addictive Desert Designs Bumpers
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
chtucker
Kirkland, WA
FJ Cruiser
I like it minus the tow "hooks" on the bottom. They look like they will get caught on every rock.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Broncotrax
NORCO
69 Bronco, '17 Superduity, '22 Badsquatch, CR 250R
not suitable for rock crawler types. it's like having an extremely fat lower lip.
Bison
Fj cruiser, Power wagon
Unless they can bang on the rocks without bending no thanks. The ones I have seen for trucks are pretty week.
rtaylor
R
ID
19Raptor, 22Bronco
Have you guys seen the new ADD bumpers? They look pretty bad-ass, especially once you start adding a winch and some lights. Debating doing this on our shop truck, what do you guys think???
I think ADD missed the mark completely when they blocked the camera to add the light bar. Hopefully they will try again because they usually have good stuff.
It would be great if you could offer a solution to fix the disturbing walleyed lights on the maxlider bumper:
Ford Bronco Addictive Desert Designs Bumpers 1632518198479
Warn also has a problem. Warn has no idea what fog light can be mounted and there are apparently no mounting provisions in the bumper:
Ford Bronco Addictive Desert Designs Bumpers 1632518317449
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
I don't think they honestly care about a camera.. when you want lots of things like lights and winches mounted, you have to give up some other things
BossMann
Louisville
2009 Honda Pilot
They might not care, but many rock folks do. Many of us are patiently waiting for an acceptable comprise
cbrownabq
Littleton, CO
Dodge 2500 diesel
Still waiting on one with an integrated hitch.
TRMFAM
OK
66 & 73 Bronco, 21 MDX A-Spec, 20 Raptor
I agree completely...if they don't care they should have done more market research! I will buy a front winch bumper but not until one comes out that adequately addresses the IC, ACC and front camera.
hellahella
Adrian
Nevada
Ford Bronco
Do you care about approach angle? Maybe someone would make something for you that addresses your 3 concerns, but i think approach angle to some of the designers are higher on the list than your 3
TRMFAM
OK
I disagree...2 of the 3 are addressed on this bumper and for the third there are a couple of options...camera relocation or a bumper that is actually closer / slimmer in depth to the body improving approach angle. The slimmer option may / will require an IC relocation also but those are common on the Raptors and required on several of the ADD bumpers.
Also, from the pics I don't think approach angle went into the design of the tow points on this bumper but could look different irl...
brosdom
Dominic
GA
F150, Wrangler TJ
I kinda like it because it is not too bulky.
