KABQ
Aaron
Albuquerque, NM
That's awesome! I have a ton of that lying around at work. I might have to "acquire" some of it.
So that’s what the wash down rear end cargo bed looks like.
Nice rail as well - I considered doing something similar with unistrut but ended up doing molle panels
Area51BS
Ron
Badlands non SAS 4dr 2.3
That’s cool!
desibull
Mahesh
Chandler, AZ
BMW 335i
This is really nice. Can you please post a link to the specific track you have installed?
CoolContractor
Fred
Here is the Amazon info for the track and tie downs. The Nut serts are 1/4" x 20 and the screws are Allen head, stainless countersunk, 1/4" x 20 x 2".
The holes for the track are accessible from underneath so if you want to put nuts and washers below, it is possible. I did not because if I want to take the track out to remove the rubber matt/cover, it will be a lot easier to do so. Also, there are wires and tubes below, so do nut drill without a limit collar as shown in the picture. Before the final assembly, I applied silicone sealer around the perimeter of the Nut serts and inside the threaded area to seal them. The tracks nearest the back tailgate/door look like I cut them too short. This was cut there on purpose due to the track mounting holes. I was making sure there was plenty of support even though these tie downs won't be holding as much weight as the factory D rings. If you need any other details or advice, ask away.
Ford Bronco Cargo area tie down rings track (airline track) install L track
Ford Bronco Cargo area tie down rings track (airline track) install Tie down hooks
Ford Bronco Cargo area tie down rings track (airline track) install Counter sunk
Ford Bronco Cargo area tie down rings track (airline track) install Counter sunk with scr
Ford Bronco Cargo area tie down rings track (airline track) install Limit collar
Ford Bronco Cargo area tie down rings track (airline track) install Underside drivers sid
desibull
Mahesh
Chandler, AZ
BMW 335i
Thanks a bunch! This is very helpful. The additional tie downs are so needed as I found out over the memorial day weekend picnic trip. Thanks again for the more detailed installation instructions as well!
Poppavein
Redmond, WA
Harleys, Ducatis, 2024 Bronco
Very nice.
I used to go to the Boeing Surplus Store for cool parts and materials like this, good times.
But, alas, it appears they shut it down. Damn Internet.
wavydave
G8 GXP, 04 F150 FX4, Wildtrak 2DR, Badlands 4DR
KABQ, is this one of yours? 912 was at KLRD in May '22 for a job in Mexico, but in a different livery than what you have in your avatar.
Ford Bronco Cargo area tie down rings track (airline track) install PXL_20220522_164618452
Bruno
Bruno
Sierras
Ineos put this stuff all over the exterior of their Grenadier.
How can we also integrate it to the exterior of the Bronco?
Ford Bronco Cargo area tie down rings track (airline track) install Grenadier_review_09
Ford Bronco Cargo area tie down rings track (airline track) install sl_349127129_ineos-grenadier-2022-side-view_4x
cr117
PNW
Bronco, EV6
I was wondering if we could make a bracket that fit between the hard top and body.
like without effecting it being waterproof.
Trailrax's pak rax would pretty much accomplish this:
Ford Bronco Cargo area tie down rings track (airline track) install IMG_8380
Bruno
Bruno
Sierras
Ooo yea glad to see im not crazy. Looks like you can wedge something in there
Trailrax should have just ued a series of the airline profile instead of inventing their own molly panel thing
