Form Lighting
Lux Sponsor (Level 2)
Form Lighting
St. Charles, Missouri
Form Lighting is excited to introduce our Selectable DRL LED Headlights for the 2021+ Ford Bronco!
Our Selectable DRL LED Headlights are the perfect way to upgrade your 2021+ Ford Bronco. With these premium OE-grade replacements, you’ll add quad projectors, sequential turn signals, startup sequence, LED running light, and a selectable DRL that gives your ride a more aggressive, modern appearance.
Increased Light Output. These headlights feature four LED projectors, which provide increased output for both low beam and high beam. The top two projectors function as your low beam, while all four projectors function as your high beam, providing a sharp, strong beam pattern to illuminate the road ahead.
Startup Sequence. These headlights are packed with the latest and most modern lighting functions, including a unique startup or “welcome” sequence. Anytime the running lights turn on, they will illuminate in a sweeping pattern across the entire lamp, gradually increasing in intensity until it fully illuminates.
Sequential Turn Signal. The startup sequence isn’t the only thing that stands out. These headlights also feature an integrated sequential LED turn signal. Every time the turn signal is activated, amber LEDs in the horizontal bar activate in a smooth, chasing sequence. When you’re finished making your turn, they automatically “switch back” to your chosen DRL color.
Selectable DRL. These headlights feature a selectable DRL with a clean diffused optic, that allows you to choose between cool white or amber. Best of all, you can switch colors easily using a simple connector. There is no need to take the headlights off the vehicle!
OEM-Grade Construction. Form Lighting headlights are built with quality in mind, using OE-grade materials and design techniques. This includes durable UV-coated polycarbonate lenses, automotive-grade LED emitters, breather vents, and OEM plug-and-play connectors. They are assembled in an IATF 16949-certified facility, which is a quality management system designed for the automotive industry. While they may not be the cheapest option you’ll find, you can rest assured that these lights will provide durable and superior performance.
Road Legal. Form Lighting headlights meet all SAE, DOT, FMVSS, and CMVSS standards and regulations for legal on-road use in the United States and Canada, when installed and aimed properly - which is easy to do with the integrated screw-type adjusters.
Plug-and-Play. Plug-and-Play. Our headlights for the Bronco are completely plug-and-play for simple installation. They were designed to plug into your factory headlight connector, and they fit perfectly without any gaps. No errors, flickering, or hyperflashing!
Click the video below to see HOW to install our 2021+ Ford Bronco Selectable DRL LED Headlights!
Two-Year Warranty. All Form Lighting products are rigorously tested for reliability, and backed by a two-year warranty. The warranty is supported directly by Form Lighting, and any replacement parts, if needed, are shipped quickly from Form Lighting’s US warehouse. On the rare occasion that you may need to utilize your warranty, we try to keep the process as simple as possible - for example, no return is normally necessary.
Click HERE to check out our 2021+ Ford Bronco Selectable DRL LED Headlights!
Do you have additional questions? We’ll be happy to help!
• Reply to this thread
• Send us a direct message
• Email: [email protected]
Are you a US forum member? DM us for a FREE shipping code!
Logan Z.
Form Lighting​
BroncoStorm
Storm
El Dorado Hills
2018 Jeep Grand Cherokee
Took me roughly 30 minutes to install on @otgbadlands and WOW, what a difference in light output and overall look. Had to run the AMBERS because well it just pops. The cutoff line is insane I feel like I’m driving a new AUDI OR PORSCHE.
Also, you save some weight as the stockers were surprisingly heavy!
Form Lighting
Form Lighting
Form Lighting
Not even gonna look at the cost....man those are great.
Our option is the best value at one of the lowest prices compared to competitor options with the same features! On top of that we are having a Black Friday sale! I will post updates regarding that here soon!
Sargeant Pepper
Missouri
2022 Big Bend
Are the bulbs able to be replaced DIY? I seem to remember replacing them yourself was an issue with the Alpha Rex lights
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
In real life, do you actually see all of the indvidual LED diodes that seem to be prevalent in the photos?
MannyG20
Ted
F-150
I have the Oracle Bi-Oculus and am very happy with them but these are very good looking. They looked ‘cleaner’ than stick. I really like that.
tock13
Tony
WA State
The coolest thing I like about OEM headlights are the big round orb with nothing on it. If you couldn’t see I the individual leds in these bulbs I’d be in. I like the big empty full moon look of my stock bulbs.
TahoeTexan
Tod
Reno, NV
2022 Bronco OBX
How is light output compared to original LED headlights?
SafariJeff
Lake Tahoe, Nevada
1994 Defender / 2020 Rubicon / 2023 Wildtrak
Hey guys, I noticed the new Bronco OEM LED headlights do not get hot…. problem for snow storms, had to pull over and wipe off the headlights every 20 minutes. Any chnace these produce enough heat to melt snow to keep the headlights clear in a snow storm?
Form Lighting
Form Lighting
Form Lighting
There are no bulbs. It is one LED board. If an LED is going to see failure it will occur in the first two years of use. Otherwise, the lifespan of LEDs is generally 40,000 hours. That is why we cover all our products with our standard two-year warranty.
