- Nick
- Aug 21, 2023
- 27
- 235
- 406
- Bethpage, NY
- 2022 Ford Bronco
- Badlands
Add-on a Front Receiver Hitch mount to your Bronco with a high winch mount like the Ford warn winch mount. It mounts to the same bolt pattern as the winch with the provided longer bolts.
Currently tested with the modular bumper and high winch mount from Ford with Warn 10,500 lb winch and Turn Off-Road high mount for modular bumper. Should fit most high winch plates with full access to bottom.
Hole pattern is 4.5″x10″
Includes: 4 – 10mm x 1.5 x 40mm bolts and washers.
Steel Construction with powder coated finish.
Product Dimensions ‏ : ‎ 12 x 5.63 x 4.5 inches
Weight: 9lbs
On sale for $129.99 IN STOCK
Shop here: Front Receiver Hitch
Code: bronco6g for additional 10% off for forum members.
Weight: 9lbs
