35tires
'23 Bronco, '21 4Runner
h
Ford Bronco 8 Untitled
adamruiz2001
SoCal
Ford SVT Lightning
It all depends on Amp ratings for the lights you choose.
35tires
35tires
I'm looking at the 20" baja designs light bar s8:
Wattage/Amps: 112W / 8.12A
and the baja designs squadron pro 3" cubes
Wattage/Amps: 40W / 2.90A x 2
sklnbnzaz
Graham
Phoenix
Bronco, Ranger
If you're using up fitter switches in the bronco you should have no issues with amperage on any switch. Save 1 and 2 for your higher amperage draw items. I would use the Driving Combo for the bumper and Wide Cornering for the A-Pillar (Ditch lights) pointed out at a 45 degree angle. You will not likely, however, be able to legally run any of these lights on road or highway, off road only...
Ford Bronco 8 upfitter amperag
35tires
35tires
I am using them on dirt trails, nowhere big open places to rip. Not a person in sight for dozens of miles.
swooshdave
Portland, Oregon
Mustang
Gtrekker
Gary
If you are using the Uplifter switches, it easy stuff...
For me, I'd run spots on a roof light bar for the most light penetration for distance if you are running pedal down and do floods for the pillars with combo in the bumper.
Ford Bronco 8 20221210_185653
Ford Bronco 8 20220925_164753
scotman623
Saratoga Springs NY
Chevy LT Trail boss
Simple way to figure out amp size for fuse is take the total wattage divided by Voltage most batteries are 12.5-13.5 volts = Amp- fuse size.. Good for future reference..
