8 inch screen ? frame is blah, anyone filling it with black carbon etc..?
Ajusaf
AJ
VA
Just curious what ideas you guys have floating around. I prefer the 12 inch but with BD, it won't be an option
Ford Bronco 8 inch screen ? frame is blah, anyone filling it with black carbon etc..? IMG_2318
Gene Dios
Atlanta
Ford Explorer
Pretty sizable gaps between the screen and vents on either side of the screen. Could be a good spot for a vertical phone mount if you're willing to drill. Maybe there's another more clever way. Just about the perfect width for current phone sizes though.
Ajusaf
Ajusaf
AJ
VA
Well that was the purpose of the brackets on the dash for connecting phones and cameras. But like you said, you have options within those gaps. If nothing else, painting it black or something to give the illusion of a larger screen. The gray just makes it look much smaller
Gene Dios
Atlanta
Ford Explorer
I'm pretty sure that accessory bar will be an add on. And it's probably aluminium so it's nice and sturdy for multiple attachments so probably going to run you $150. Then you need some sort of arm that holds your device that interfaces with the bar. Probably another $80. Check out some similar products for jeeps. If you don't need to mount two phones, an iPad, a go pro, ect, it might make more sense to just get creative and add your own basic phone mount somewhere and that gap seems like a good spot.
Blackandbluebronco
Christopher
Wichita Falls, Texas
Ford Expedition
Definitely would find something to do with it. It’s good real estate though to get an aluminum bezel cut out to go around the screen to make an accessory mount for an additional gps, sat phone, or a CB radio mic. There should be good struct points behind it that could handle the weight.
rjkmoto
JK
2017 Dodge Challenger Hemi 392 Scatpack Shaker, 2020 Jeep Gladiator Rubicon
Keep in mind these are all pre-production interiors and Ford - at every opportunity - keeps stressing this and that these interiors are not the quality of the production units.
In other words they loo cheap and ugly because they are cheap and ugly. Test rigs don’t need lambskin leather and engineers don’t care about panel gaps when they are collecting driveline data.
JK
Ajusaf
Ajusaf
AJ
VA
JK
Very true, but just incase, it’s better to start noting any updates you would like Incase they don’t clean it up. Plus it will keep us busy while we wait for this final order to go through ?. I hope they do make that dash a little more exciting from the center around the screen to the passenger side
King Luis
Toronto
Volvo XC60 & MK5 Jetta TDI
i don't know what to say. should that have made the dash completely different to accommodate a smaller screen and not offer a larger one?
is the trim the issue? i'm sure you can pop it off easily and paint it, put a sticker on it or even replace it with something else. seems like such a small thing that once seen in person will not be an issue.
like another person has said, it's a pre-prod model. quality of things will change and QC will be much tighter. what else would you do with that area?
Dom
Dom
Phoenix AZ
2000 Ford Expedition, 2013 Ford Fusion
I threw Carbon 3M inserts in my Black Mustang and it looked really good. I'm sure the aftermarket will be all over this. Just get a good quality set, with 3M backing. I'm ordering the 12in screen to avoid those gaps. :D
BEM-S4
Philadelphia
BMWs & Porsches
Proclip will do something...
Slyder
Washington
2014 KTM 1290R
Just hide it with an Alpine Halo 11 ;)
it would work, if you can live without the Sync 4, since it would retain the factory features with the right adapters.
I haven't found an article, yet, that has said you can retain Sync 3, and I'm going to assume the same will apply to Sync 4 also.
tyrobronco
CC
Central Florida
2021 Bronco,2017 Ford Fusion Energi
This never would've crossed my mind unless you posted... it doesn't bother me at all and I would leave it as is. I guess I am a simpleton
Agreed. I measured out my wife's screen (which is too bright at night) and it was 8 inches. I can't imagine have something 4 inches larger. Just measuring it on her car would take up the entire center of the dash. 🤪
I look at the OP's picture and it doesn't bother me at all.
