Status
Not open for further replies.
Shifts And Grins Fab
Ryan
Gilbert AZ
shiftsandgrinsfabrication.com
2023 Badlands, 2022 Bronco Wildtrak Sas
We just got our 2023 Badlands recently and have started the build. We are Diode Dynamics and Pro Eagle Jack dealers and working on other things on the back end to offer more parts to compliment our offerings. We are new to Broncos but from new to Fabrication and mechanics. So far we love our Broncos and want to document our build from the beginning. We started out buying everything Diode Dynamics offers for our current Bronco. We have most of it wired but still have a few items to fab up, install and wire. We will link the items to our webpage or another webpage if it isn't and item we sell.
Here we go:
We started out with installing the Diode Dynamics Reverse Light kit and Diode Dynamics HitchMount. These greatly increased the amount of light behind the Bronco and we love these two kits. We did as some others have done and did not run our wires outside of the vehicle and back in (Photos attached) and found this to be a solution we liked better. The HitchMount is a plug and play and installs in a few minutes. It plugs into the backside of the 7 pin trailer harness. There are no warnings and the vehicle does not think it has a trailer connected. The reverse lights used the Diode Dynamics harness supplied in the kit to tie into the lights and the factory wiring. These lights work automatically and are tied into the auxiliary switch using the factory wiring so the main beam can be turned on manually as well. We used auxiliary switch 3 for these lights.
View attachment 505781 View attachment 505783 View attachment 505785
Here are the links to the HitchMount and Reverse Light Kits:
https://www.shiftsandgrinsfabricati...true&sa=false&sbp=false&q=false&category_id=8
Next we installed our fog lights. These are plug and play and say they don't work with the capable bumper but they do. It is my understanding they say they don't work because you can't adjust them but we found them to be aimed perfectly. We went with the yellow driving lens and amber back light. We used the supplied harness to plug the lights directly into the factory harness and then ran the backlight wiring up to the firewall and tied into auxiliary switch 6 where all but our Windshield Mount back lights are wired. We installed our Ditch Lights/ A Pillar lights at the same time. We went with SS3 Pro clear with a driving lens for these. We also opted for an amber back light. The back light is wired to aux 6 and the main beam is wired to aux 2.
Ford Bronco Shifts And Grins Badlands Build IMG_4775
Ford Bronco Shifts And Grins Badlands Build IMG_4614
Next on the list was the SS5 windshield kit. This kit is insane!!! We opted for the pro version because overkill is our personality but I'm certain the sport version would be just fine. This kit is 7 SS5 Pro pods linked together. We drilled a hole in the windshield frame on the drivers side and ran the wires down the A pillar and through the firewall. The install isn't too bad but take your time. We can help anyone that needs it on this or any other install. We wired these back lights to a separate auxiliary switch (Switch 5) so we can control them separately from the other back lights. We used the provided harness and wired the main beam to auxiliary switch 1. The backlights are selectable to different colors and the main beams are freaking bright!!!. We changed all of our lenses out to clear driving pattern. The photo below and videos I have taken do not do the light justice. I cannot express how bright and amazing this bar is. In these photos the wiring was run up the windshield channel but we later ran it inside and drilled the hole in the windshield frame.
Ford Bronco Shifts And Grins Badlands Build IMG_4827
Ford Bronco Shifts And Grins Badlands Build IMG_4837
Ford Bronco Shifts And Grins Badlands Build IMG_4845
Ford Bronco Shifts And Grins Badlands Build IMG_4846
Next on our list is rock lights. We have them mostly installed but will update this thread when they are done.
Let us know if we can assist with anything. Lots of great parts and accessories coming for the Bronco from us.
Ryan
Gilbert AZ
Rock lights installed and ADS Racing Suspension Installed. We are moving a little slower than we'd like due to being busy with the business and life.
We installed 8 rock lights which does the job perfectly. We love overkill though so we will install more. Why? Because we can and love overkill. lol
We will have a full write up on the ADS kit soon. It is so freaking awesome. I installed it in my driveway at my house with basic tools to show everyone they can tackle it themselves if they choose to. We will include a complete tool list as well. We are so excited to get some miles on this kit.
Ford Bronco Shifts And Grins Badlands Build IMG_4879
This is the rock light kit we installed with the added bluetooth controller.
Here are a few pictures of the ADS kit and Bronco with it installed. We haven't touched preload at all. We will drive it as it shipped with the exception of turning the compression adjustors 5 clicks from the softest.
Ford Bronco Shifts And Grins Badlands Build IMG_5038
Ford Bronco Shifts And Grins Badlands Build IMG_5037
Ford Bronco Shifts And Grins Badlands Build IMG_5036
Ford Bronco Shifts And Grins Badlands Build IMG_5039
Ford Bronco Shifts And Grins Badlands Build IMG_5040
Ford Bronco Shifts And Grins Badlands Build IMG_5034 (1)
Here is the link to the ADS Bronco Kit.
I still have a 30" light bar I need to make mounts for and a 12 switch auxiliary controller I need to make mounts for and install. We are also working on lots of fabricated parts we ill make for this Bronco and yours.
Thanks for checking it out.
Ryan
Gilbert AZ
We got out to test flex and clearances a bit. I am super happy with the ADS kit.
Ford Bronco Shifts And Grins Badlands Build IMG_5054
Ford Bronco Shifts And Grins Badlands Build IMG_5052
Ford Bronco Shifts And Grins Badlands Build IMG_5051
Ford Bronco Shifts And Grins Badlands Build IMG_5043
Ford Bronco Shifts And Grins Badlands Build IMG_5042
Ford Bronco Shifts And Grins Badlands Build IMG_5049
Ryan
Gilbert AZ
Ryan
Gilbert AZ
We got some 37s on. Wrong wheels currently but at least we got to test the +25 offset as opposed to the 0 offset we ordered. We also ordered Titanium and go Machined Finish. The correct Methods should be here soon.
Ford Bronco Shifts And Grins Badlands Build IMG_5389
Ford Bronco Shifts And Grins Badlands Build IMG_5408
Ford Bronco Shifts And Grins Badlands Build IMG_5396
Ford Bronco Shifts And Grins Badlands Build IMG_5390
Ryan
Gilbert AZ
The new correct wheels came in. We haven't flexed these yet but the new ones are 0 offset and Titanium color (Which is what I ordered). @Discount Tire is awesome and got the correct wheels in right away and got them installed. I definitely recommend Discount. I've used them for years and they have never let me down.
Ford Bronco Shifts And Grins Badlands Build IMG_5417
Ford Bronco Shifts And Grins Badlands Build IMG_5418
Ford Bronco Shifts And Grins Badlands Build IMG_5419
Ford Bronco Shifts And Grins Badlands Build IMG_5420
Discount Tire
Arizona, USA
discountti.re
All Things FORD
A very good looking, and capable rig! Thank you for your patronage, and thanks for sharing!
Ryan
Gilbert AZ
Thank you for the assistance getting an awesome set of wheels and tires. The customer service was awesome which is why I always end up back at Discount when I need wheels or tires.
snowcatxx87
Canada
1290SDR EVO / 701SM / Tiger 900RP / Grom / Surron
Interesting name lol - I read it as Shifts and Grinds, like you had an issue with the clutch / transmission or something hahaha
Dom
Dom
Phoenix AZ
2000 Ford Expedition, 2013 Ford Fusion
Very nice rig! How did you run power for the light bar? Are those SS5's?
buzpro
Binky
Tacoma
Here we go:
Nice build ..... So are you just an online retailer? you dont have any fabrication or installation facilities, right?
Ryan
Gilbert AZ
We do have a fabrication facility in Gilbert Arizona. We are working on a ton of Bronco parts. We tig weld everything we build that requires welding. We started with a few universal products and did some Toyota and Jeep stuff in the beginning. We then switched to mostly Ram products until we picked up our Bronco. We are now working on lots of Bronco parts. If you have anything you’d like to see made that isn’t currently made or you’d like to see it made different or better, we are always open to suggestions and keep a list of parts to add as we have time.
I added a bunch of photos of products we have built or finished for customers over the last year or two. The aluminum bumper on the Ranger was a kit a customer bought. We welded it, blended it, powder coated it and installed it.
Ford Bronco Shifts And Grins Badlands Build 5370C5FD-C495-45BD-9CA3-F733DA374943
Ford Bronco Shifts And Grins Badlands Build 49C4A85E-C81C-48B5-A946-E158211F3752
Ford Bronco Shifts And Grins Badlands Build B5DEEA22-3B0C-462F-8D5C-4121C18872AD
Ford Bronco Shifts And Grins Badlands Build 527D12A8-87F1-4498-9315-5BD33E96466A
Ford Bronco Shifts And Grins Badlands Build 82691C69-7865-4D56-8D04-2B1D9305C600
Ford Bronco Shifts And Grins Badlands Build 06C0FD66-57FC-4DF4-AAE3-8A5852661057
Ford Bronco Shifts And Grins Badlands Build 59D3C9C2-8405-47DE-AC0B-CC5D3F0CC63E
Ford Bronco Shifts And Grins Badlands Build 367C2417-BD76-47B5-A01E-0CCE54AA39EC
Ford Bronco Shifts And Grins Badlands Build B9D7994C-EAC2-4189-A757-09C3243BD370
Ford Bronco Shifts And Grins Badlands Build 1F430548-51C5-4B5D-9879-6C6E2CBEA658
Ford Bronco Shifts And Grins Badlands Build CA270DBF-0C71-4008-8164-64F234C9CAF2
Ford Bronco Shifts And Grins Badlands Build CAA6982A-24CB-42D9-9D4F-9A80D5BC96C7
Ford Bronco Shifts And Grins Badlands Build A093F585-CCEF-4FF4-B29C-E44F60263B09
Ford Bronco Shifts And Grins Badlands Build 93B986BC-9273-4CCE-8CDB-E9955A61DA90
Ford Bronco Shifts And Grins Badlands Build 54EEF5A5-B56B-4E81-9852-C457FED6E505
Ford Bronco Shifts And Grins Badlands Build 407DF795-3E41-4EE1-BF35-3A8F1F24C961
Ford Bronco Shifts And Grins Badlands Build BD05828D-5AC4-4DA6-AA24-681F6F8FEFCC
Ford Bronco Shifts And Grins Badlands Build 53FB3CA4-EF7A-4A0A-B2A2-6D93C7198B4C
Ford Bronco Shifts And Grins Badlands Build 1C46F1B6-E3F2-45C9-9E7E-31C6945D429B
Ford Bronco Shifts And Grins Badlands Build 2B4074A7-5651-40AC-8C5B-8113E021C864
Ford Bronco Shifts And Grins Badlands Build CAD17920-B7DD-41B3-9A66-48A751BD50F7
Ford Bronco Shifts And Grins Badlands Build 8298BE18-1254-4B56-9876-30BA4DFD27AB
Ford Bronco Shifts And Grins Badlands Build A895AEA1-8EC0-4B8D-AEC6-F97CA2D736F8
Ford Bronco Shifts And Grins Badlands Build 5B4F0D89-68B3-4903-9499-F2D47D2E2618
Ford Bronco Shifts And Grins Badlands Build 0742B9CA-EA5E-41DA-A5AF-9C5C69FF1B3B
Ford Bronco Shifts And Grins Badlands Build 70ADB914-3C3E-4C85-8936-9C6C19832DD3
Ryan
Gilbert AZ
Those are SS5 pros. They are insanely bright. I drilled a hole just large enough for the wiring harness to fit through. The home is on the drivers side between the two mounting studs. After I ran the wiring harness through I ran a bead of silicone around the harness to insure it is sealed. It also sits under the lights mounting bracket as well. I have had zero moisture issues. I ran the wires down the A pillar and behind the dash and then through the firewall.
Status
