Chritaka
DFW, Texas
'23 WildTrak; '06 Whippl'd Mustang (sold4upgrades)
I was at the dealership yesterday and they had all 3. My current WT, vs the BL I ordered, and a Braptor inside... Thought I'd share the visual comparison. It may just be my eyes, but seems like the WT are larger in diameter than even the Braptor...
Also, the WT Fox's dwarf the Bilsteins... After a test drive back-to-back, the Fox's were quite a big difference.
'23 WildTrak Hoss 3.0:
Ford Bronco Tie Rods visual comparison: 2023 WildTrak Hoss 3.0 vs Badlands SAS vs Bronco Raptor IMG_5835
'23 Badlands SAS:
Ford Bronco Tie Rods visual comparison: 2023 WildTrak Hoss 3.0 vs Badlands SAS vs Bronco Raptor IMG_5836
'23 Braptor:
Ford Bronco Tie Rods visual comparison: 2023 WildTrak Hoss 3.0 vs Badlands SAS vs Bronco Raptor IMG_5837
Bronco_Buckeroo
Brandon
Washington
2023 Bronco Wildtrak
May be because of the crook in the BL & WT rods vs the straight line of the Braptor tie rods. The bend may require more material to hold integrity while pushing/pulling with a bend in it.
So glad I got HOSS 3.0! Love the ride on the Foxes! Mine’s MY23 WT, so it came standard.
Now, if Ford could just stop building with bad CV boots, that’d be great…
https://www.bronco6g.com/forum/threads/blown-cv-boot-from-the-factory.70093/
Chritaka
Chritaka
DFW, Texas
Here's a pic of the WT next to the BL. The WT w/Hoss 3.0 seems to sit slightly higher in the front. I didn't have a tape measure, else I would have got measurements...
Ford Bronco Tie Rods visual comparison: 2023 WildTrak Hoss 3.0 vs Badlands SAS vs Bronco Raptor IMG_5829v2
broncoj11
Everglades
Trunks
Ford Bronco Everglades
Everglades
Might be the fender flares that make it seem like they have a difference in height.
Chritaka
Chritaka
DFW, Texas
They do open up the wheel wells, but compare the bumper line and top grill line. Salesperson also thought it looked .5-1" higher.
H0pelessOpus
2015 Xterra PRO-4x
What type of fender flares are those?
Chritaka
Chritaka
DFW, Texas
KBD 4dr flares Lots of people have had issues with the tape not sticking well. I cleaned everything perfectly and followed the install procedure 100%, even added extra 3M in a few areas, but they’re still coming up a bit in a few spots. Recommend removing tape, cleaning with Ajax and redoing with 3M. The Ajax was their recommendation.
There’s a couple threads on them if you search.(y)
KompressorV12
Portland, Oregon
19' Jeep Grand Cherokee High Altitude
Badlands has more steel plates. Also could be a diff in how full gas is. In my experience I’ve felt HOSS 3.0 has been shorter by .4” than HOSS 2.0. But now that I have a 2” lift with 37s over SAS they all seem small lol
Chritaka
Chritaka
DFW, Texas
Yeah, good points. I was at ~1/4 tank too. Now to figure out which one to keep!😵
Tex
Cliff
San Angelo
Probably the same diameter, but given that they're longer that would make them appear proportionally thinner.
BCRaptor
Jon
BC
2022 Shadow Black Bronco Raptor/Ford Procal. 2019 Lamborghini Urus
Inner tierod…
Have a quick question: is the inner tie rod. My truck was struck by a car in the front end. And snapped the inner tie rod. It’s a bronco raptor. What are my options, if any, as ford is back ordered on the stock part, and I need it drivable.
TxMike
Miguel
Ford Bronco
@BCRaptor -try rpg. They have a complete tie rod kit but pricey at about $900. They will get u back on the road though.
4runner
4runner
Los Angeles
Ford Bronco Toyota 4 Runner
I have tied the rod to a Sasquach, it was amazing and it worked way better than the HOSS 3.0, its called SOSS, Sasquach Operating Sequential Suspension, nothing like it !
Inlinejohn
WA
Several
The breaking point looks same between all three, just a little more inward on Braptor
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
'23 Badlands SAS:
'23 Braptor:
Yup, those tie rods are a whopping .1 of an inch larger…
