brtd
Iowa
23' BL, '15 LR4, '22 Beta 390-RS
The plan has been in the works for a few months, mostly waiting on parts and compatible weather. The weather is here now, but still waiting on a few parts. I'm taking my time and hopefully being careful enough to be able to put it all back together. I'll share some pictures and thoughts throughout the project.
System Components:
  • Amplifier/DSP: mObridge A2B 8.1.1
  • Kick Panel Woofers: Stereo Integrity TM65 mkIV
  • Tweeters (L/R dash): Stereo Integrity M25 mkII
  • Midrange (L/R dash and center): Stereo Integrity M3 Carbon
  • Subwoofer: TBD - waiting on the Stealthbox. We'll see.
  • Sound Deadening - a mixture
There are all sorts of threads and videos out there showing how to remove the guts from the Bronco, so I won't be reinventing the wheel. I will say that anyone endeavoring to go to this length will be glad if they have a variety of panel and trim removal tools and some mega-beefy torx sockets. I have this set for the trim. And this set of torx sockets... a must have when it comes time to remove the seats (and a good length breaker bar). My Dewalt impact wanted nothing to do with the a couple of the bolts.
I'll be running the front L/R stage as active 3-way, with the two higher powered channels of the amp going to the kick panel woofers. Lower power channels to the mids and tweeter. That leaves two of the lower powered channels. One for the center channel... and I'm not sure yet about the rears. I will figure that out along the way. The amp included an additional harness that will leverage the three amp channels in the head unit itself. I will probably use them to power the rear speakers if I don't scrap them altogether.
The midrange for L/R are being cnc milled in order to fit closer with the tweeter and deal with the cramped stock location. That work is in progress this week, then they go to "The Mesh Man" to fabricate the mounting plates for me.
One additional element to this project is the addition of seven sound FX buttons I am adding just below the hero switches. I had seen this Mark Rober video years ago and always wanted to give it a try. I have a separate cheap amp for this, and I've already mounted the PA horn speaker just above the front skid plate.
Here's my status as of today:
Ford Bronco Stereo Overhaul - Mild Documentation doors out sid
Ford Bronco Stereo Overhaul - Mild Documentation doors-out-rear2
I had installed the soundskinz kit along with some additional dynamat I had on the 4 doors a few weeks back. I have some blackhole for the rear and other spots. I have the soundskins kit for under the 4 seats as well. Still need to get the rubber floor liner out before I tack that part.
Ford Bronco Stereo Overhaul - Mild Documentation dynamat
Ford Bronco Stereo Overhaul - Mild Documentation soundskin 1
Ford Bronco Stereo Overhaul - Mild Documentation soundskin 2
Here's a peek at the buttons. Not shown is the Adafruit SFX board attached to another ethernet keystone jack. Space was too tight to try to have the buttons and the board in close proximity. This will let me connect the two with a single cable so I can put the board somewhere accessible... for changing out the sounds.
Ford Bronco Stereo Overhaul - Mild Documentation buttons front
Ford Bronco Stereo Overhaul - Mild Documentation buttons wired
And here's the speaker under the engine.
Ford Bronco Stereo Overhaul - Mild Documentation horn speaker
More to come...
Silence
SD
2022 Bronco
very cool. excited to see what your thoughts are after. You'll be definitely missing a sub I'm sure after adjusting the rest.
brtd
brtd
Iowa
No doubt. I have no intention of running it without a sub. I'm just not sure what I'm going to do yet.
I'd rather not sacrifice the cargo space with a swing gate mounted enclosure. But it's unclear when JL will ever bring their stealthbox to market.
Silence
SD
2022 Bronco
I'd rather not sacrifice the garbo space with a swing gate mounted enclosure. But it's unclear when JL will ever bring their stealthbox to market.
What about running a jl8w1 for now? Seems it fits in that space per multiple users.
Silence
SD
2022 Bronco
or with the powerr you are pushing, maybe a Kicker 48CWRT84
brtd
brtd
Iowa
Wash out floor removed. That was tricky. Going back in should be worse.
Last pic is the other side of the button project, which will connect with ethernet to the button array.
Time to sound deaden the floor. Then on to wiring.
Ford Bronco Stereo Overhaul - Mild Documentation PXL_20230412_153257760
Ford Bronco Stereo Overhaul - Mild Documentation PXL_20230412_152741913
Ford Bronco Stereo Overhaul - Mild Documentation PXL_20230412_152958981
John P.
Orange County, CA
BMW X5
And so it begins! Woah. Looking forward to your progress.
gringoloco
Alabama
2023 2-Door
Yaaaaassss! All the way in.
I have the same SI components to install, and patiently awaiting the JL Stealthbox. I also explored the Mesh Man dash, but settled on the MTI version as they said they could do it without speaker surgery. My second set of M3s are slated for the rear, no center channel.
Breaking out the popcorn for this one
LakeLife
Wayne
Ct
2017 Shelby Gt350/1970 Bronco/ 2023 Bronco
I consider myself a can do it all …. Most…,but this is a little out of my league. My hats off to you sir, looks to be quite an undertaking.
Following this thread.
brtd
brtd
Iowa
Nice, another SI fan. To be honest, I've never even heard these components but I've known Nick for a long time and have had a range of his HT subwoofers for years. Currently a couple of his HS-24s in my living room.
I know I had come across MTI, but I must've been steered away by the limitations of sizing on their website. Good to know there's a backup option. I am curious to see how they worked it out. It is pretty tight quarters.
I'm blessed to not be in a hurry. I'll probably be twiddling my thumbs waiting on the components in a few days. I have another vehicle I can use in the meantime. Without that, I would be rushing and breaking things no doubt.
This is beyond any level of vehicle interior surgery I've done before. I did have a moment thirty minutes ago before taking a lunch break... looking from the tailgate side and thinking "WTF have you gotten yourself into". Haha.
I've found it to be less complicated than I was anticipating. I'm labeling every bolt and screw hole cover and taking a ton of pictures because I know my memory won't be fresh when it comes time to stitch it all back together.
I'll share some more pictures later today. I have one more piece of floor deadener to install, then I'll go around and fill in the gaps with extra material. After having used a blank rectangle for the trunk area, I am very pleased with the precision cut pieces used elsewhere from Soundskinz. It would take exponentially more time to be cutting and test fitting everything from blanks.
brtd
brtd
Iowa
Here's the floor coverage from the Soundskinz kit. FYI, they will sell the floor kit separately from the doors even though it isn't a SKU on their website. I had accidentally purchased the doors only kit.
It had appropriate cutouts for everything except these three rear seat bolt holes. These were overlooked (red circles in last pic).
Ford Bronco Stereo Overhaul - Mild Documentation PXL_20230412_180958084
Ford Bronco Stereo Overhaul - Mild Documentation PXL_20230412_181014700
Ford Bronco Stereo Overhaul - Mild Documentation PXL_20230412_181018413
Ford Bronco Stereo Overhaul - Mild Documentation PXL_20230412_181227535~2
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
ThisGuy611
E90 M3 6spd Sedan; EG Base Scheduled 3/27
This is above and beyond, looking forward to seeing the finished product!
Also makes me wish Ford just sold an actual sound deadening option for $1,000 or whatever from factory. I'd love some peace and quiet in the bronco, but have no interest in removing the entire interior to do so.
omg_bbq
Eli
Oakland, CA
www.instagram.com
2022 EG BD SAS
Same bud
