SuperFord
2013 Ford Fusion
Two different Base trim, manual transmission, 2 door Broncos nose to nose.
Red is obviously stock
Black one added 3.5” lift & 37” Kenda Klever on Raceline wheels.
Ford Bronco Before & After (stock 2dr Base vs. 3.5” lift + 37’s). What a difference! IMG_3608
Ford Bronco Before & After (stock 2dr Base vs. 3.5” lift + 37’s). What a difference! IMG_3600
Ford Bronco Before & After (stock 2dr Base vs. 3.5” lift + 37’s). What a difference! IMG_3601
Ford Bronco Before & After (stock 2dr Base vs. 3.5” lift + 37’s). What a difference! IMG_3604
Ford Bronco Before & After (stock 2dr Base vs. 3.5” lift + 37’s). What a difference! IMG_3607
dan79
dan
ma
08 f250
thats a big jump up! what comes on a base it looks so small
DesertMike680
Las Vegas
What are your thoughts on the Kendra's? I see theyreca little cheaper than leys say the Falken Wild Peaks. Wondering how they compare as my Big Bend needs some 285s.
KompressorV12
Portland, Oregon
19' Jeep Grand Cherokee High Altitude
Who she tells you not to worry about
Butzy
Butzy
Brookfield, Ohio
f150 & bronco
Why am l not surprised?
JT58Bronc
JT
Fl
2022 Bronco, 1987 Chevy Squarebody 4 X 4
Wow, looks like the lifted one with the huge tires can almost drive over the base one!
Blackcat
South Carolina
2022 FORD BRONCO BASE 2 DOOR M/T
As a bone stock Base owner, I agree that it doesn't look great in photos, especially next to one that's been lifted. However, in person, I think it looks much better. I had wheels and tires ready to change out on my base, but have held off because it looks so much better in person. To each his own though...
Lucky Nut
Memphis, TN
97 TJ
Ford Bronco Before & After (stock 2dr Base vs. 3.5” lift + 37’s). What a difference! rookie-numbers
