7/13 Blend Folks
luptanpitman
Los Angeles
'21 Bronco, ‘21 Polestar
7/13 + 4098 - I got my "you're vehicle is on its way" email last night so it has shipped and tracker is updated with that info as well. Dates on both. Getting closer and frankly aside from my manic checking, the information from Ford from their tracker and emails have been pretty spot on - a few days later but otherwise fairly accurate.
audipwr1
Matt
Cali
ford and others
hard tops have stopped is what I am concluding
KyTruckPlant
Goshen, Ky
05 Mustang, 05 F150, 08 Expedition EL, 23 Bronco
Still no "built" status or emails.
Mine is probably sitting in some lot waiting for someone to repair it, already.
You'd think they could repair these things quicker than a week. If it don't get repaired in the next 2 days I'll likely have to wait another full week with the down week coming up.
Ford Bronco 7/13 Blend Folks 1626893205429
CO-Bronco
CO-Bronco
Canada
www.instagram.com
2021 - 4dr - Cyber Orange - Badlands
MIC top?
Tricky Nick
Nick
St Charles, IL
2009 2dr JK, manual, AEV lifted, 35’s
the pic attached, if you can say, where was it from and what is significance of the highlight and 1 circled?
Lord Bronco
Lord Bronco
Lord
Jeep Wrangler
Anyone know where I can see a map of Jack Cooper distribution routes?
KyTruckPlant
Goshen, Ky
Without reference, I guess this doesn't make sense, my apologies.
This is from the error proofing report on my VIN. I was able to access it for about a day, then it dropped off where I couldn't access it again.
The yellow "1" represents 1 required process (in this case a bolt/nut torqued to the correct specifications AND correct degrees of angle after torque, I presume), the green box is number of required processes completed, and the red box is the number of processes that failed for that particular station on the assembly line on that specific unit.
I had other things that had failed, but the number of completed processes were good, so no worry there.
For example, there are 5 bolts that are required to be tightened to a specific torque (AND angle)during a process. Only 4 pass, so you get 1 fail. You retry the one that failed and it passes, you end up with 5 required, 5 passed, 1 failed, no concerns.
If a process (in my case the right side upper instrument panel bolt/nut) fails and isn't repaired before it goes to the next line, then that unit is held until that concern is addressed and properly repaired.
On my sheet it looks like there are 1800+ quality control stations our trucks go through that ALL have to be "bought off" before they are released.
Trust me, we (at Ford) try our absolute best to make sure everything is right before we release a single job.
Unfortunately, I got the one that has a concern.
The story of my life...
I did go test drive a WT today at my dealer. It felt a little like a consolation prize knowing my BL is sitting on a lot 6 or 7 hours away 😒
Tricky Nick
Nick
St Charles, IL
Hearing this is a process in place, feels reassuring!! Thanks, and good luck in the BL moving 6-7 hours to your garage!
MustangRanch
Kentucky
66 GT350, 11 GT500, 20 GT500
my Ford tracker and B6G tracker just updated from
"awaiting shipment" to "delivered". Palsapp still says "pending"
hoping this make everyone feel better....
Awesome and congrats. Hopefully mine will do the same!
Lord Bronco
Lord Bronco
Lord
Jeep Wrangler
Mine shipped on 7/16 (convoy) and is still “In Transit.” Wonder why it hasn’t arrived yet.
MustangRanch
Kentucky
Just for shits and giggles try tracking it via rail car. It might be rail with convoy and sticker still marked convoy.
Bronco55
Tim
New Jersey
2014 Ford Fusion, 2007 F150 FX4
