Caleb@PandaMotorworks
Caleb
St Louis MO
Introducing the FIRST Aftermarket Valved Exhaust for the 2021+ Ford Bronco! This XForce exhaust features a Varex muffler, which allows you to go from Louder to quieter with the flip of a switch. This isn't just a party trick on an average exhaust system, the XForce exhaust comes jam-packed with additional features! These features include, mandrel bent 304SS construction, high-tuck design for additional ground clearance, & included options to run a Polished tip or high clearance exhaust dump all at a great, low price! This exhaust truly is an EXCELLENT Value! This exhaust requires no irreversible modifications for a truly plug-n-play system! Get yours today!
  • 3″ 304 Stainless Steel Mandrel-bent Construction
  • Sound Volume Adjustable Varex Muffler
  • Straight-through Design for Maximum Power and Sports Sound
  • High Tuck Design provides additional ground clearance over a standard cat-back
  • Polished Exhaust Tip Included
Ford Bronco The First VALVED Exhaust for the Ford Bronco! XForce Exhaust [With Video] XForceBronco_940x788
Ford Bronco The First VALVED Exhaust for the Ford Bronco! XForce Exhaust [With Video] aled_76530f19-9478-4731-b8e0-1a8140e1d93d_1408x736
Caleb
St Louis MO
We have limited quantities on stock, so get them while you can! We are doing an introductory 10% off while supplies last. Don’t wait, take advantage now!
Ford Bronco The First VALVED Exhaust for the Ford Bronco! XForce Exhaust [With Video] XForceBroncoFlyer
Tdifonzo
Thomas
Audi S3
I've been waiting for a valved exhaust, but the DC adapter and fob control cheapens this in my opinion. I wish there was a way to use the AUX switches instead of the fob. Anybody know if that's possible?
Caleb
St Louis MO
Im sure its possible, but could not tell you how. The DC adapter I assume would be easy to cut off and tap into a power source.
ManSquatch
Washington, DC
23' Bronco, 17' F250
I think its a cool idea, might not hurt to look into being able to activate with one of the accessory switches instead of the remote. Did you get a dyno test on the system? I would also be curios if there was an increase in power with the valve opened.
Biggwrm
Orran
Gilroy CA
2018 Raptor
No thanks on the remote. It come across cheap and gimmicky. I know it’s hard to get a feel for exhaust thru video but I hope it sounds better in person. The 2.7 valved sounds like it rattles 😬
Yea it sounds like crap with valve closed. Open sounds decent.
Id like to see one with dual tips.
also anyone know if the dc port in the back is powered key off? Wonder about battery drain
EOSeabee
Patrick
Las Vegas
2022 Ford Bronco 4 Door Badlands
There is an AUX wire right there in the rear cargo area.
chris@pandamotorworks
St. Louis
2016 F250, 2013 Ford Focus ST
We can sell you a hardwire kit but the aux switch could not work to control the the valve as its a momentary switch to allow you to adjust the valve position.
You can upgrade to the smart box which uses the fob or the app to control the valve.
Being that there is not an oem valve the remote is the only way really to control this without installing a switch which would be a hole in a dash etc.
The entire point behind the dc plug is easy of install and not needing any wiring skills. I commend them for keeping it simple. Their system is far from cheap and the best on the market in my opinion
St. Louis
The valve needs a momentary switch so no way for the aux switch to work as it can not go but one way.
We did not get a strict dyno session on exhaust only yet. Its in the works but from past experience with these motors will be minimal gain.
St. Louis
It is cool. I really do not like anything about the wiring.
At the end of the day we installed it the easiest way we could think of. If you would like to route it differently and hardwire the box its a easy option to do
St. Louis
it does not rattle in person. The remote is the only way to properly control the valve so you can have it at any position you want for your desired sound level.
zero battery drain the dc powers off after 10min I think.
The valve fully closed is quieter than stock. you can have it at 10% 20% etc to get your desired sound level.
Thank you
Bronccraig
Craig
Orlando Florida
2009 Challenger RT Hemi Orange
Where is the side exit exhaust in front of the back tires with mr thrush glasspacks option? Lol
USAGUY
Ny
. understandable.
