Status
Not open for further replies.
PTTyler
Tyler
Lodi, CA
powertank.com
2022 Badlands Sasquatch
Check out our Bronco Plate mounting system! Developed to mount a 5 lb, 10 lb, or 15 lb Power Tank securely in the back of your Bronco, it also works to mount 5 lb to 11 lb propane tanks. In addition to a Power Tank or propane tank, there are pre-drilled holes to mount a quick-release fire extinguisher bracket as well an expansion slot toward the front for future expandability (currently in development).
Ford Bronco New part: Mount for Power Tanks, propane tanks, fire extinguisher bracket 085A5957y (Large)
I'm going to stick with the exciting news up top but if you haven't heard of Power Tank, it's the fastest and most reliable way to air up your tires and I'll give a brief overview at the end of this post. I'll make a new thread if I get enough questions about just the Power Tank.
Ford Bronco New part: Mount for Power Tanks, propane tanks, fire extinguisher bracket Bronco-Roll-Bar-Clamps-Main
Because of the unique shape of the Bronco's roll bar we couldn't re-use our round roll bar clamps to mount a Power Tank and call it a day. We took the opportunity to come up with a clean sheet vehicle mount based on what we had learned from our previous Jeep Wrangler mounts. With the excitement of an all-new vehicle platform, the idea was to come up with modular parts that worked well together or separately. To that end, we started with bespoke billet roll bar clamps. They are rubber lined so to not scratch your paint and can be used by themselves to mount just about anything. Powdercoated satin black.
The next piece is the Bronco Plate. This is a 3/16 steel plate powdercoated satin black with a few bends to increase rigidity. There are a few sets of mounting holes and 3/8 stainless steel hardware to fit multiple brackets. When mounted, towards the rear of the vehicle is a spot to add one of our billet quick-release fire extinguisher mounts. And towards the front of the vehicle, behind the rear seats is an expansion slot. We have a MOLLE/PALS panel planned but want to know what other things you'd like to be able to hard mount. A small rubber bumper stops the bottom of the plate from coming in to contact with your interior trim. There are separate driver and passenger mounts.
Ford Bronco New part: Mount for Power Tanks, propane tanks, fire extinguisher bracket Bronco Plate QR Bkt 3
The Bronco Plate fits 5 lb, 10 lb, and 15 lb Power Tank Super Brackets as well as brackets for 5 lb and 11 lb steel propane tanks and 6 lb and 10 lb aluminum propane tanks. Right now, I have my 10 lb Power Tank on the driver side panel with a fire extinguisher and, on the passenger side, a 5 lb propane tank and a second fire extinguisher bracket, but this one houses a Pro Eagle Phoenix CO2 jack.
What really has me excited about the Bronco Plate is how freakin' solid it is when it's all bolted up. I can shake the Power Tank handle and it will rock the whole vehicle. For a vehicle platform designed to offroad faster than the Wrangler competition, this is key for peace of mind and safety on the trail.
Ford Bronco New part: Mount for Power Tanks, propane tanks, fire extinguisher bracket 085A5952 (Large)
What is a Power Tank? Starting in 1997, Power Tank is the original CO2 air system for off-road. With a high-flow, high-pressure Super Flow regulator, Power Tank is the fastest, most reliable, and most powerful portable air system for airing up tires, running air tools, and more off road. A 10 lb Power Tank like in these photos can air up a 37" tire by 15 psi in about 30 seconds and fill 18 tires on a single tank. With no moving parts or wear items, Power Tanks are dead reliable and all come with a limited lifetime warranty. We routinely see Power Tanks over 20 years old so we can confidently say that a Power Tank is the only air system that will outlive the vehicle it's mounted to.
Power Tanks are refilled with CO2 at any number of welding supply, beverage carbonics, home brew, hydroponics, and aquarium businesses.
Our XP400 outputs 400 psi which is much more than any air tool on the market was designed for. To that end, we make our own line of Ventoso Tire Inflator Gauges, blow guns, and other air accessories that can handle this immense pressure. For general air tool use, our regulators can be dialed back to an acceptable input pressure.
Where's the 2 door mount? It's coming! We have finished round one of design and are cutting our first prototype. As long as there are no snags, we'll refine the design a bit and then hit production for a target release date of May. This design mounts using the bolts going in to the top and puts the Power Tank lower, on the ground behind the rear seats. It will fit 5 lb and 10 lb Power Tanks and select propane tank brackets with more options if you remove or fold down the rear seats.
I hope I can answer some questions in the replies.
Use "Bronco6G" at checkout for 10% off any complete Power Tank system.
We have Bronco Packages available in 5 lb, 10 lb, and 15 lb. These all use our most popular Package B as a base and adds the Bronco Plate. The bundle includes a complete Power Tank system, Super Flex Hose, Upgraded Super Coupler, complete Bronco Mount, Ventoso HD Tire Inflator with case, and a new Carbon Regulator Cover. Lmtd lifetime warranty on the bottle, regulator, and handle; 5 year warranty on the Ventoso Tire Inflator.
5 lb: https://powertank.com/products/5-lb-bronco-edition-power-tank
10 lb: https://powertank.com/products/10-lb-bronco-edition-power-tank
15 lb: https://powertank.com/products/15-lb-bronco-edition-power-tank
Tire inflation chart: https://powertank.com/pages/tire-air-up-chart
General recommendations:
For tire emergencies and a few trips on stock tires - 5 lb Power Tank
Up to 35" tires - 10 lb Power Tank
35"+ - 15 lb Power Tank or 10 lb Power Tank with a second 10 lb rotation bottle
BroncoAZ
Mitch
I bought my first Power Tank at Moab EJS in 1998, my buddy is still using it on his Jeepster today. I like the look of this mount, but I have a 2 door and don’t want something that goes on the floor. I pulled the rear seats and made a platform to mount my ARB fridge and camping gear, definitely need every square inch of floor space in my 2 door.
Tex
Cliff
San Angelo
Why are you putting the 2dr mount closer to the ground? Isn't it just a matter of adjusting the angle of the existing 4dr plate to match the angle of the 2dr roll bar? Or is the roll bar being more vertical causing the clamps to slide downward?
PTTyler
PTTyler
Tyler
Lodi, CA
powertank.com
Noted. The original plan was to roll bar mount the Power Tank like our 4 door version but with the speaker pod, there is not enough room on the roll bar. Would you be willing to sacrifice the speaker pod for a Power Tank?
PTTyler
PTTyler
Tyler
Lodi, CA
powertank.com
The clamps won't slide down. I wouldn't hesitate to mount a Power Tank to an Ultra4 Race Car using our mount. It's a clearance issue. There is not enough space to mount a Power Tank on a 2 door roll bar with the speaker pod attached.
The roll bar profile is actually different between the 2 door and 4 door for whatever reason. We have a 2 door roll bar clamp already designed but when we started to mock up the Power Tank mount, we just couldn't figure out a way to fit it up high while retaining the speaker pod.
PTTyler
PTTyler
Tyler
Lodi, CA
powertank.com
Space in the back of the 2 door is rough. This is my knock-off setup. @Tex
Thanks for sharing these pictures. Our final mount will look similar to this in terms of Power Tank placement. Also, it will be driver side only because it would end up blocking the light and the storage pocket on the passenger side. We have made cutouts to be able to access the hard top wiring slots for when you're topless.
alancorman1
Corman
Houston TX
2022 Ford Bronco
Are you putting together a Bronco package on your website versus piecing it together? This looks like a great product to add to my Bronco.
Jimmiee
Reno, NV
Chevy Silverado
Following. I have a 2 door with the rear seats removed. I have the Smittybilt knock-off tank. I assume the mounting is the same as the Power Tank?
351W-Bronco
Herb
Southern New Mexico
2023 Bronco,1969 Bronco, 2001 Excursion (7.3L)
Will the plate also have "extra" holes to accommodate things like Quickfist mounts? That would allow extra versatility to mount items like an Element Fire Extinguisher.
Herb
modestdave
Laguna Beach, CA
2022 Ford Bronco Raptor
What kind of modification will be required for the Bronco Raptor to install this product? Is this feasible for the Braptor without weakening structural integrity?
Joez60421
Joe
Illinois
Fleet of Toyota 4runners and Land Cruisers
Hope your 2 door mount is ready here before June so I don't have to fab one ahead of my Moab trip!
PTTyler
PTTyler
Tyler
Lodi, CA
powertank.com
Way ahead of you! These all use a Package B as a base and adds the Bronco Plate. The bundle includes a complete Power Tank system, Super Flex Hose, Upgraded Super Coupler, Bracketry, Ventoso HD Tire Inflator with case, and a new Carbon Regulator Cover. Lmtd lifetime warranty on the bottle, regulator, and handle; 5 year warranty on the Ventoso Tire Inflator.
PTTyler
PTTyler
Tyler
Lodi, CA
powertank.com
Yes, any tank with 6.9" dia should work.
Herb
Where do you want the extra holes to be located? For an Element FE, you should have no problem installing the Quick Fists where our billet QR mount would go. On the right side of this picture which is showing a passenger side mount - front of vehicle would be on the left.
Ford Bronco New part: Mount for Power Tanks, propane tanks, fire extinguisher bracket BKT-2210-P-with-labels
Status
