Quake LED
Mr Bojangles
Denver
quakeled.com
Ford Bronco Sequential LED Tail Light - QMT1192
Product Description:
Cracked your stock plastic tail lights or looking for an off-road durable design? Quake LED is proud to introduce our “First To Market” all metal housing Ford Bronco LED Tail Lights! Replace your full size 2021+ Ford Bronco with a set of Metal Tek Series - Quake LED Ford Bronco Tail Lights! This powder coated, all stainless-steel construction features high impact resistant lens, ultra-bright reverse lights, high visibility red side markers and our signature Tri-Phase Sequential Turn Signals!
Providing enhanced visibility for a safer driving experience. These premium LED tail lights provide a halogen bulb-free design that is waterproof and its extremely durable all metal construction protects against any potential trail damage. Over engineered with highly advanced circuitry to protect against voltage spikes.
A complete DOT/SAE/ECE compliant, plug and play installation with built in anti-flicker resistors and easy to follow instructions. LED offers an all-metal construction and quality that is built to last. Order model number: QTE1192 today!
• COMPATIBLE with/wo factory Blind Spot Monitor System!
• No Drilling required!
• No Painting required!
• ALL Components are included!
Quake LED Features:
• Function - Running, Brake, Reverse & Sequential Turn Signals
• No dash errors or hyper-flashing (*See Notes below)
• Watts – 24W
• Current: Running Light - 0.2A @12VDC per side
• Current: Brake – 1.0A @12VDC per side
• Current: Reverse - 0.7A @12VDC per side
• Diode Count - 326pcs LEDs per side
• LED Color Temp - 6,000K (Reverse)
• Lens Material - Thick Polycarbonate
• Housing Material - Stainless Steel
• Housing Finish - Powder Coated Black
• IP66 Waterproof Rating
• Operating Voltage - 12V DC
• Operating Temp -40 to 140 degrees F
• Life Span Expectancy - 50,000 Hours
• Compliant: DOT/SAE/ECE
• Weight: 8lbs/set
• Size: 6x13 Inch
Fitment:
• 2021+ Ford Bronco with Factory Halogen Tail Lights (Base Tier)
• 2021+ Ford Bronco w/LED *Will Require ForScan Flash (High Tier)
• Will not fit Bronco Sport or Bronco Raptor
Included In The Box:
• Fully Assembled Driver and Passenger LED Tail Lights
• LightHACKER Modules
• Instructions
Note 1: Base Tier model requires additional installation of our Light-HACKER module to feature sequential turn signals. (all parts included)
Note 2: High Tier model will require flash FORSCAN at Ford dealership in order to remove Dash Error/hyperflash.
Quake LED Metal-Tek Series:
Providing enhanced visibility for a safer driving experience with a plug and play installation. These premium lights provide a bulb-free design that is waterproof and extremely durable against potential trail damage. Constructed with a powder coated, military grade, stainless steel housing and impact resistant poly-carbonate lens that will not yellow. Giving optimum protection against the abuse of road debris, and impact from branches on the trail. Sealed with reinforcement grade epoxy that protects the innards from corrosion and moisture. Engineered with advanced circuitry to protect against voltage spikes. Quake offers a quality that is built to last.
Ford Bronco Quake LED Releases Ford Bronco Metal-Tek Sequential LED Tail Light! - QMT1192 Bronco_tail-09 (1)
Ford Bronco Quake LED Releases Ford Bronco Metal-Tek Sequential LED Tail Light! - QMT1192 Bronco_tail-08
Ford Bronco Quake LED Releases Ford Bronco Metal-Tek Sequential LED Tail Light! - QMT1192 Bronco_tail-07
Ford Bronco Quake LED Releases Ford Bronco Metal-Tek Sequential LED Tail Light! - QMT1192 Bronco_tail-05
Ford Bronco Quake LED Releases Ford Bronco Metal-Tek Sequential LED Tail Light! - QMT1192 Bronco_tail-04
Ford Bronco Quake LED Releases Ford Bronco Metal-Tek Sequential LED Tail Light! - QMT1192 Bronco_tail-03
Ford Bronco Quake LED Releases Ford Bronco Metal-Tek Sequential LED Tail Light! - QMT1192 Bronco_tail-02
GI_Jo_Nathan
Jonathan
That's not a bad price, especially for those with the Base lights.
$439
Garemlin
Delaware
Interesting look. What's the warranty??
Quake LED
Quake LED
Mr Bojangles
Denver
quakeled.com
$439
That's exactly what we thought...those base model halogens just don't belong... We fortunately decided to change that :)
Quake LED
Quake LED
Mr Bojangles
Denver
quakeled.com
All of Quake LED's products are rated for 50,000 hours and have a 1-year warranty on paper. That said, we under promise and over deliver: if you experience any issues beyond that you should still reach out to us as you will still be taken care of!
Quake LED
Quake LED
Mr Bojangles
Denver
quakeled.com
FleshTuxedo
A
PA
'22 OBX 2dr.
My first thought too.
They're not for me, but not mad that there are options for people who may be into something like this. Bring on all the aftermarket parts. You won't be buying these, nor me, but different strokes for different folks.
Garemlin
Delaware
I like the under promise over deliver. But just wondering why some of you LED light manufacturers offer such short warranties. Oracle is another. Companies like JW Speaker, KC, and Diode Dynamics have 3-5 year warranties. Sometimes longer. Hell KC offers a 23 year warranty on their Gravity Pro lights.
dan79
dan
ma
08 f250
like the idea to but looks kinda ugly I think I would rather see more stock looking light that do the sequential turn thing and have bright reverse lights
sorry
