4DR, Soft vs Hard top
markregel
markregel
Lincoln, NE
Pont Vibe
You absolutely can swap between hard and soft (just like in real life.. ha).
Haha! I'm leaning towards hard even if it Nancy pol
In that case Nancy Polosie will ban hard tops, better get it quick.
Hahaha ?. In that case better go with soft. Won't be needing the hard what with hearing Nancy Polosi's voice on the news everyday. Heck they might even ban it.
Jr87mustang
Josh
Northern Cali
markregel
markregel
Lincoln, NE
Pont Vibe
Until we see a freakin' video of just what it does and how....we're guessing. For one, you have to decide if you're ok with the gray MIC top or not. I kinda got used to that.....but I really wanted to remove those rear glass panels and have the bikini/safari look much of the time. So that pushed me back to the soft top....but if it isn't made by Best Top...and it's 50/50 on that...it depends on how it works. But if it's not by BT and I don't like it, then what? Spend $700 on a hard top I don't want and then $2k from BT to get one I do want later????
I'm going with carbon grey and happy with the way the MIC top looks.
ProSim
Pro
Pittsburgh
Bronco Heritage
Saw this earlier on Facebook:
This is the clearest pic I have seen of the rear lift capability. It appears to still function even in the sun-rider position. While it look goofy, I can tell you this is a nice feature compared to my JKU.
I was looking forward to this feature but now that I see it I wonder how that plastic window holds up in the cold weather? In my mind I thought the entire thing was going to lift on an angle so the windows would stay "flat".
Headsong
A lot of fiats here in Chicago area and tops hold up fine. Most soft top videos I've seen show removing windows before folding.
ProSim
Pro
Pittsburgh
Bronco Heritage
Good to hear they hold up. I was thinking this feature was going to help with loading things in the back when you come out of the store etc., Hoping it was going to be a some kind of flip up, load, flip down, and away we go so yeah taking the windows out is not an option but I was hoping thinking they should stay flat to prevent long-term repetitive cracking. I know I always hated the jeep soft top zipper window being in the way when loading in the back. Either way its nice to have!
Headsong
Surely they won't have that old zip design! But we don't know much yet....
PrincipalD
Ryan
Sioux City, IA
Expedition, Bronco
If you order a soft top, will it come ready for a hard top conversion? Meaning, will it have electrical and plumbing for wipers, washers, etc?
Headsong
Yes.
Jarrett
JJ
Wilmington, NC
Acura RDX
Looks like the rear section normally would lift with the side windows flat, except they also have the convertible top pulled back which looks like it is limiting the rear from lifting up properly.
BLee
Barry
Lancaster PA
2020 Wrangler Rubicon Unlimited
If you go soft top from Jeep you do not get wiring for the rear defrost, wiper, or the rear washer tank and plumbing.
Has it been confirmed from Ford that you get all the wiring and plumbing for the hard top if you do not get a hard top?
And if the soft top opens like the JL you won’t have any zippers. But, be prepared to spend a few minutes taking the side windows and rear windows out. You can’t put the top down completely with those left on.
AleYeah
Greenville, SC
2014 Wrangler Unlimited, 1976 VW poptop Bus
Soft top is a lifestyle choice. It's great to be able to quickly switch back and forth between covered/open when there are rainstorms, after you drop the kids at school on a sorta chilly morning, etc.
BuckinT29
Travis
Los Angeles
Alfa 4C Spyder, Ducati V2, BMW X1
It all depends how Ford set this up. Prior softtop / hardtop experience it was one or the other. Use the soft top for summer and swap to hardtop for winter. I eventually went full softip all year long because it was just easier.
Hardtops were a bitch to fully remove alone and you needed at least two people to remove the rear.
Noise levels are subjective until we see a video.
Headsong
There will be a video? ?? When the unicorn returns I'm afraid.
