TheGhost
Central TX
2021 Bronco Badlands, 2020 BMW M2 Competition
Once I heard that Deepsleep would be making a memory foam Solo mat for the 4 door, I immediately asked if they would be doing the same for the 2 door. I was somewhat disappointed when the response I received was that the 2 door version would instead be an air mattress. After digging through specs of other vehicles that Deepsleep also makes the Solo mat for, I realized that the Subaru Impreza dimensions are nearly identical to that of the 2 door Bronco. So I purchased a Solo mat for an Impreza to see how well it would fit in the 2 door. I didn't want to have to remove the seats and in this case the angle created by the rear seat helps the Solo mat fit more snug. So I had a custom piece of medium density foam cut so the portion of the mat near the tailgate would have something to rest on:
Ford Bronco Deepsleep mattress for 2 door Bronco (Proof of Concept) IMG_7773
Test fit of the Solo mat and the foam (mat is inflating):
Ford Bronco Deepsleep mattress for 2 door Bronco (Proof of Concept) IMG_7774
Fully inflated mat with the tailgate closed:
Ford Bronco Deepsleep mattress for 2 door Bronco (Proof of Concept) IMG_7775
Here is the portion that is not a direct fit...the armrest. Instead, it actually sits on top of the Bronco armrest. This actually helps add stability/cushion to the underside of the mattress:
Ford Bronco Deepsleep mattress for 2 door Bronco (Proof of Concept) IMG_7777
The upward angle of the seat and mattress actually allows me at 5'10" to lay comfortably on the mattress. However, I'll probably double up on the mattress and foam for camping with my girl (or if I just want to lay diagonally).
So here's another option for fellow 2 door owners.
618TRVLWILD
Ashley
Southern Illinois
Big Bend Sasquatch 2D
Out of curiosity how tall are you?
Nevermind I read further see your height.
Also do you not prefer flipping the bottom portion of the seat up to where the seats are more flat and less of an angle?
DC9atnight
Toyota Tacoma
Great solution! Do you mind sharing the mattress measurements?
TheGhost
TheGhost
Central TX
The mattress is 72" long and either 26" wide (thickest portion) or 21" wide (thinnest portion). It inflates to 5 " thick and made out of similar polyurethane material that Exped or other sleeping mats are made out of. The air can be pressed out and the mat rolled up and put in a storage bag that Deepsleep provides
TheGhost
TheGhost
Central TX
Laying completely flat would be my first choice but you would have to put some sort of cushion or padding under the mat so that it can clear the portion of the rear seat cushion that is sticking up when you lay the backseat flat.
66GT
Thomas
Tacoma, WA
03 Marauder, 66 Mustang GT, 65 Ranchero, 64 Comet
I think you need to cheat using that wrong-fold-up angle to smooth the transition up to the forward-leaned seat back... only way I'd fit at over 6'.
Probably like being in a recliner. Park it downhill... prop the feet a bit... it might just work for a non-restless sleeper. 🤔😴
Gilligans_off
Vince
Canada
2022 2 Dr Bronco Badlands Sas/lux
thesocalexplorer
Joe
Southern California
This is awesome!!
Zero_chance
JD
AZ
www.southvalleymustang.com
17 Mustang
If only they came in adult size.
JasonB
Pilot
TheGhost
TheGhost
Central TX
How much over 6' are you? A mattress on both sides would allow for diagonal sleeping and add a more room. With the front seat pushed all the way forward to fit a 72" long mattress and based on a 42" width the max diagonal angle is 83"
