Ryan at ARB
Ryan
Auburn, HI
arbusa.com
Jeep LJ, Ford Ranger, Ford Bronco
ARB is no stranger to off-road protection equipment. Although our very first product was a roof rack, a functional off-road bumper followed suit soon after. In fact, bumpers are one of the parts that we are most known for. Not only do they enhance the look the vehicle, they also drastically increase the strength of the front and rear end.
As technology improves, vehicle manufactures have increased the safety of their vehicles, whether it be from sensors, radars, air bags, cameras, etc. While these added features can become a hurdle for many off-road accessory manufacturers. Our bumpers stand out with the built-in ability to maintain and work with OE factory safety equipment. Rather than leaving them unplugged and living with the Christmas tree look on your dash, ARB’s engineering has developed ways to relocate these items to maintain their usability. Both front bumpers and the rear bumper include pre-drilled holes for the parking sensors along with plugs for the models without sensors. Both front bumper options include relocation brackets for the adaptive cruise control radar and forward-facing camera. To ensure they are unobstructed, the relocation brackets attach to a free and clear portion of the bumper.
Ford Bronco ARB Bumper Line Up for Your Ford Bronco BRONCO safety
Our full range of Bronco accessories features two different style ARB front bumpers (Summit and Zenith) along with a rear bumper.
Ford Bronco ARB Bumper Line Up for Your Ford Bronco brocnosidebyside
ARB Summit & Zenith Front Bumpers
Each of these bumpers include two structure jack points along with two 8T frame mounted recovery points that suit traditional 4.75T bow shackles or an ARB Soft Shackle. The oblong shape of the ARB Recovery Points allow the shackles “D” end to be fed through the hole, rather than placing all the load on the shackles pin. This also allows the shackle to rotate toward the point of recovery rather than the strap being at an angle which causes premature wear.
Summit Bumper
The Summit Bumper has the classic ARB full protection brush guard with modern enhancements to match the body and maintain the factory safety equipment.
Recovery is simple with the ARB Summit; the built-in winch mounting system is ready for a Warn winch up to 10,000lbs. Twin jack points rid the critical and creative thinking when looking for a structured point to use a farm jack or its safer alternative, the ARB Jack. The same goes for the recovery points which are conveniently located on both the left and right sides of the bumper.
Inset in the bumper you will find LED parking/signal lights along with mounting points for your OE fog lights (or ARB fog lights if OE are not equipped). On top of the bumpers main body are pre-drilled holes that are designed to accept up to a 9” round light (ARB Solis 32 shown). Or leave out the off-road lights to expose the fan favorite BRONCO logo in the grill.
Other Features
  • ARB Integrit finish (black texture powder coat)
  • EDP20 Ecoat under powder coat used for additional corrosion resistance
  • Installed weight of 172lbs
  • Compatible with ARB Under Vehicle Protection (PN 5480100)
  • Clears up to 37” tire with suitable suspension lift and rim off set
Ford Bronco ARB Bumper Line Up for Your Ford Bronco summitbronco
ARB Summit Front Bumper
Zenith Bumper
The latest and greatest, Zenith, is a new edition to the ARB bumper family. It features all the essentials that an off-road bumper needs with a minimalist approach.
Like the ARB Summit, the Zenith offers the same twin recovery and jack points. It also maintains the factory parking sensors, adaptive cruiser control radar, and forward-facing camera.
The removable skid front skid plate comes powder coated silver. However, this powder coat is the perfect base layer for those that would like to add their own custom touch.
The Zenith also includes an integrated LED Light Bar with an output of 6900 RAW lumens. The bumper kit includes both the light bar and wiring harness. On the left and right side of the bumper are pre-assembled fog light housings that are designed to suit your OE fog lights or optional ARB Fog Lights.
Two models have been developed to suit either the wide (Sasquatch Package and Wildtrak Trim Level) or narrow flare models.
Other Features
  • Zinc rich primer for additional corrosion resistanc
  • Installed weight of 133lbs
  • Not winch compatible
Ford Bronco ARB Bumper Line Up for Your Ford Bronco zenithbronco
ARB Zenith Front Bumper
Ford Bronco ARB Bumper Line Up for Your Ford Bronco bronco zenith widths
Narrow vs Wide (roughly difference 1" per side)
Zenith Rear Bumper
Combining functionality, strength, and protection, ARB has designed and developed a rear bumper that retains the OE tow bar. In true ARB fashion, the rear parking sensors are also compatible. We also include blank plugs for those models without sensors. To compliment your ARB front bumper, the rear is powder coated with the same Integrit black coating.
Included with the bumper is a license plate relocation bracket that moves the plate to the center of the spare tire. Rear recovery was not forgotten; we were sure to include twin jack points and 8T recovery points for those sticky situations.
This bumper is also offered in two different widths to suit both the wide flare and narrow flare models.
Other Features
  • ARB Intregit finish (black texture powder coat)
  • Zinc rich primer for additional corrosion resistance
  • Installed weight of 155lbs
Ford Bronco ARB Bumper Line Up for Your Ford Bronco zenithrear
ARB Zenith Rear Bumper
Cmptn845
Henderson
16 pilot, 16 frontier, 10 maxima
Love the look of the summit, is that V6 compatible?
sjjohnny
El Paso
'22 Bronco Black Diamond, '00 Tacoma
Don't like the summit at al... changes the Bronco's classic look, and we're paying thru the nose for that classic look! haha Zenith is ok. Maybe I've gotten to used to the production model, rear bumper is terrible... and I usually like ARB stuff!
GaryB2220
Gary
Wellsboro PA
'99 4runner, '10 Town & Country
New favorite. It's been two years and finally we've got something that can protect the front end better from kamikaze deer.
Question, are warn winches the only brand the mounting points are compatible with? What about an apex badlands?
darkscion0
Canada
2021 Badlands Sasquatch
Unless they make one specifically without it, I don't think so. The one I have is all one piece.
Can the Summit be installed without the brush bars? Would love a clean solution for a fully loaded Bronco without all of the extra bars.
Dan66
Dan
Bc
2021 explorer platinum 2014 ram limited
I like the Fact all The front End Cameras, ACC & Sensors Will fit without a bunch of extra relocate kits and parts to me they Look great perfect for Squirrel Squashin LOL
Russ.Gil
Russ
Washington State
2011 Subaru Impreza 2.5i premium
I'd love a version of the summit without the brush guard, one issue with all of these is uh, where do you mount your license plates?
Ryan at ARB
Ryan at ARB
Ryan
Auburn, HI
arbusa.com
We usually only test Warn winches but I see no problems with mounting the Apex Badlands or any others.
Ryan at ARB
Ryan at ARB
Ryan
Auburn, HI
arbusa.com
The bars come welded to the bumper frame.
Ryan at ARB
Ryan at ARB
Ryan
Auburn, HI
arbusa.com
For the Summit we include a license plate relocation bracket that will move it to the winch fairlead area. We include both a flip plate bracket (for winch users) and fixed plate bracket (for non-winch user).
Zenith has two holes/grommets in the silver skid plate.
