- Greg
- Dec 6, 2021
- 76
- 477
- 1,346
- Houston
- Website
- www.undergroundgraphics.com
- 22 Bronco, 20 Jeep Gladiator
- Badlands
The Eddie is here! Inspired by the Eddie Bauer retro styling, we’ve recreated the look normally hand done and made it into a “Cut-to-fit” kit. While the kit is pre-cut using 3M IJ180MC wrap vinyl and laminated with 3M 8518 high performance gloss, we HIGHLY recommend this kit be professionally installed. This is a DRY installation vinyl, do NOT install wet. We’ve done this kit several times now in our shop and it is a good 4-5 hour installation. A lengthy YouTube installation demonstration is available on our channel. This kit is designed to be digitally printed giving you a seamless two color graphic; however, we can do a custom single color die cut if you prefer and hand lay the pinstripe if desired. The full kit includes the hood “U” that follows the down slope of the hood bump, it even works with the Wildtrak OEM graphic (please specify this when ordering, as we have a version for our hood overlay as well). Also, the “Spear” kit which follows the upper body crease, as well as the fenders and rear lower tailgate. Available for both 4-door and 2-door models. These kits do seem to work best on darker color vehicles, but please contact us for recommendations and custom color options. Example: Eruption Green uses the Cream and burnt orange accent stripe, Velocity blue worded well with white and sky blue accent, Cactus Gray with White, and so on… We even did oarneg on our shop Bronco for our installation video, it was bright, ...too bright, but is just another example of options. As with all our kits, everything can be customized and edited. If you have any questions, please don't hesitate to message or call us direct.
Digital Print Kit (click to purchase)
Cream with burnt orange accent, White with Sky Blue accent, Call for Custom
LInk to YouTube install video (up shortly)
