4-Door Badlands time for 35s
Rumbloki
Alton
ATX/PCB
ZR2, 1973 Mach 1
Aren't the Badlands stock tires 34" (really 33.halfish...)? The stock Sas are 34.4. I've got 34.8's on my BL Sas, no lift or rubbing.
BL tires are 32.8".
GrumpyVet
Joel
Now that I have worn out the stock BGFs on my Badlands, I am ready to move from 33s to 35s. I am considering a 1" or 2" puck lift and going with Baja Boss ATs. Is anyone running this setup on a 4-door Badlands?
Am I wrong for not changing out shocks and Upper Control Arms? I am not interested in going bigger than 35s now, so I thought factory shocks were okay.
What milage did you get with the stocks?
Keith0374
Keith0374
Keith
www.ordeneaux.com
Ram 1500
I am at just under 33,000. I could likely get another 10,000, but living on the Gulf Coast of Texas, I am less confident in the rain and normally switch on 4A in these cases at this time.
CoolContractor
Fred
I'm looking at the new Bilstein 8112's. Pricey, but from what I hear, they are worth it.
CoolContractor
Fred
One thing that hasn't been mentioned is that when you go up to a taller tire, your speedometer and mileage will be off until you get it updated. It'll be a few miles off, I think showing you're going faster? If you're about to take a long trip, just FYI.
Some people never update it. When I went up to truer 35's, my two miles over came up even; now, when it say's 45 speed signs also say 45 and not 43, like they used to. I know I can update with my ProCal; maybe also FORScan.
I have been a Guinea Pig for a programming company for the last couple of weeks. They have a programmer that will allow you to adjust the tire size to get the speedo back to actual speed, and to adjust the TPMS warning to a lower amount, so it doesn't freak out when you air down. It should be available for sale in a week or so. I should be getting mine soon, so I will give a report when I get it and use it.
