IAG Off-Road
JJ
Westminster, MD
www.iagperformance.com
IAG EZ-STEP MAKES GETTING IN & OUT EASY
Stepping in and out of the new Ford Bronco can be a bit of a challenge for some, especially if the vehicle has been lifted. Whether you or one of your family members need a little boost, the IAG EZ-Step System provides just the solution to make getting in and out easy. The EZ-Step System is designed to mount to the OEM Ford rock rails found on many 2021 and 2022 Bronco models. *OEM Rock Rails are required for Installation.
https://www.iagperformance.com/ez-step
IAG V1 EZ-Step Add-on - Sits at the top of the OEM Rock Rail:
https://www.iagperformance.com/iag-v1-ez-step-for-2021-ford-bronco-2-door-4-door/
Ford Bronco New Product Release: IAG EZ-Step Add-on Kits for 2021+ Ford Bronco IAG-BDY-F2201-05
IAG V2 EZ-Step Add-on - Sits approximately 2" below the OEM Rock Rail:
https://www.iagperformance.com/iag-v2-ez-step-add-on-2021-ford-bronco-2-door-4-door/
Ford Bronco New Product Release: IAG EZ-Step Add-on Kits for 2021+ Ford Bronco IAG-BDY-F2203-03
survivormanca
Ron
texas
nothing
Just placed my order - can't wait.
Justin_Kane
Justin
Ohio
Infiniti Q50
Looked at the website, but it's unclear if these work on a Badlands Sasquatch or not. Cannot find if they have the OEM rock rails or not. Anyone know?
SVTLightning
Christian
Canada
Titan
These are designed to attach to the factory rock rails.
IAG Off-Road
IAG Off-Road
JJ
Westminster, MD
Yes the badlands have the factory rock rails these are designed to clamp to!
IAG Off-Road
IAG Off-Road
JJ
Westminster, MD
Is the orange a reasonably close match for the badlands orange accent color? Between that and black for my CG BL
Yes that is the intention. I’ll try to get a better picture of the swatch soon.
Mean Red GT
Kevin
TN
2022 4 Door Badlands/2016 Mustang GT PP
We are proud to announce that the EZ-Step V1 and V2 steps are NOW AVAILABLE for Preorder! We appreciate all of your input and we want to show our appreciation with a special coupon code for pre-orders.
USE COUPON CODE 2DOOR TO SAVE $30
USE COUPON CODE 4DOOR TO SAVE $50
Really like theses! Any idea how long you will run the coupon code? Mine isn't scheduled to be built until April and I've already bought quite a bit of stuff including your Soft Top opener.
Bt_ostate
Oklahoma/Colorado
2021 Ranger Tremor 2021 Bronco 4-Door FE
Very nice if I was using my rock rails. Problem is I needed wider steps to help keep the rocks from destroying the sides of my Bronco. Even with flaps the boards have saved me big time.
IAG Off-Road
IAG Off-Road
JJ
Westminster, MD
Currently the coupon code is live until April 1st I believe. I wouldn’t expect it any longer than that. ;)
Lifeliberty
Moonbeam👀
Columbus, OH
Is that description correct for the v2? Maybe needs edit fyi
Ford Bronco New Product Release: IAG EZ-Step Add-on Kits for 2021+ Ford Bronco Screenshot_20220225-210441_Chrom
kbBronco
Kyle
Carrollton, TX
2021 Ford Bronco, 2019 Honda Rebel 300
Just ordered a set for my 2 Door! Thank you for designing the perfect side step, in the perfect price point!
IAG Off-Road
IAG Off-Road
JJ
Westminster, MD
Thank you so much! We could have used another day to dot our “I’s” and cross our “t’s”
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Ugggh I'm torn. Great price, but just one on the passenger side is going to look funny and it will just be in the way on my side.
Michael Grasso
Indianapolis
2025 Ford Bronco
Ordered!!!!
