- Joel
- Apr 7, 2021
- 295
- 715
- 1,298
- Arizona
- Website
- www.stage3motorsports.com
- 2021 Bronco Badlands 4 Door 2.7L Ecoboost
- Badlands
With the limited availability of tires these days its nice to see something in stock, have plenty of these in stock at the moment for anyone interested or looking for tires to go with wheels.
35x12.50R17LT Nitto Ridge Grappler M/T-A/T Hybrid Radial Tire 217-020
Aggressive Off-Road Nitto Ridge Grappler Tires
Enjoy the best of both worlds when it comes to street and off-road performance with Nitto's new Ridge Grappler Hybrid tire. Providing the perfect mix of their mud-terrain and all-terrain technology, Nitto designed this tire with a revolutionary dynamic hybrid tread pattern that provides a quiet and comfortable ride on streets and highways while the deep and chunky sidewalls enable you to get through any of the worst conditions Mother Nature throws your way while off-road. The Ridge Grappler features a variable pitch tread pattern that provides a quiet and smooth ride while the lateral Z grooves are arranged in alternating widths and lengths to clear mud and maintain traction. This listing is for a single tire. Dependable Off-Road Nitto Tread Design
Nitto Ridge Grappler hybrid tires feature a tread pattern that has self cleaning high-void tread lugs for improved traction in mud and snow and also helps to naturally dislodge any rocks or debris that would normally get caught in the treads. They also have step block edges and coupling end points that strengthen the block edge to reduce irregular wear which provides excellent durability and long tread life. Each tire includes a dual sidewall design option that allows you to choose between either a traditional design or much more aggressive look.
Tire Specs:
Tire Specs:
- Tire Diameter: 34.76
- Max Load (single): 3195 lbs.
- Tire Size: 35x12.50R17LT
- Load / Speed: E 121Q
