- Oct 9, 2021
- 86
- 407
- 624
- Plymouth, MI
- Website
- www.shopmrt.com
- 2024 Ford Bronco
- Badlands
For a limited time MRT Bronco exhaust systems and no drill hood strut kits are 15% off. Use promo code MRTCharm at checkout or over the phone. www.ShopMRT.com or Call 734-455-5807 Mon-Fri 8am-4PM EST.
0:00 Start up and Drive By 0:16 Interior Driving 0:56 Backseat Exhaust Noise
SHOP - MRT Bronco Exhaust and No Drill Hood Strut Kit
2021 Bronco Outer Banks 2.3L - MRT's Trail Rated Axle Back system Part #90R232 - In this video we begin with start up and some fly by clips followed by the interior driving experience as well as the backseat exhaust sound. The Trail Rated Axle-Back gives you full performance sound when you want it while allowing for a more reserved presence when cruising. Designed for maximum exhaust flow all of MRT's Bronco exhaust systems will liven up your Bronco. The Trail Rated series was developed to allow for maximum ground clearance. The turn down tip gives the most ground clearance keeping the exhaust system tucked up and hidden from any road hazards. While the Trail Rated system with polished stainless steel tip gives a visual pop. Both systems share the same exhaust note. Installs in less than 30 minutes. Both Trail Rated systems are ready to ship today !
All MRT Bronco Exhausts are compatible with both 2.3L and 2.7L
