Bschurr
NY
While I really love the look of the super fancy multi-light set ups from Diode Dynamics, Rigid & Baja Designs that fit the modular bumper, I am not a fan of spending $1000+ for some extra light.
I bought a pair of 8 inch Rough Country Black Series single row spot LED light bars for $59.99 each and fabricated some custom brackets and installed them in the bumper & wired them up to Aux1 (yellow wire)
Let me know what you think…
Before & After
Ford Bronco 8" LED driving lights installed in MOD (heavy duty modular) bumper 82F2FE0A-4667-4A5C-8F84-0AB0221826AE
close up
Ford Bronco 8" LED driving lights installed in MOD (heavy duty modular) bumper D4B21FC3-F91E-491A-A5C2-D448E761E5E0
low beams
Ford Bronco 8" LED driving lights installed in MOD (heavy duty modular) bumper 4CF61157-B519-41D1-AAE4-B4F9FE5BFA59
low beams with LED bars
Ford Bronco 8" LED driving lights installed in MOD (heavy duty modular) bumper D2AC1D5B-53C3-44D6-AF94-6233AF6F39F8
As DRL
Ford Bronco 8" LED driving lights installed in MOD (heavy duty modular) bumper ce33e404-5932-499a-9890-245afb4b0824-jpe
Some Notes:
wanna fabricate me a bracket as well? lmao
Thank you very much - glad you like it. I enjoy doing my own work, it’s very satisfying and the positive feedback is validating.
Sorry - I didn’t document the build details with pics along the way but, it really wasn’t too difficult - just a bunch of trial & error because there is not a lot of room back there for my ham fists and I wanted to make sure the light was level and properly angled for proper output. You cannot simply mount a light bar to the bumper bolts because the bumper ends angle outward. I needed to get a little creative to mount it angled so the light is focused in front of the vehicle and not the sides - all while centering it in the bumper opening so it works well & looks good too!
Basically, there are just 2 metal brackets that I fabricated to hold each end of the light bar.
The outside mount is 1/2” wide flat bar that is 2.5” long that I drilled holes @ 1.75” on center. (I harvested this from a black powder coated L bracket). This is attached horizontally to the outermost bolt on the underside of the bumper on one end and the other end is attached to the supplied end of the light bar via a 1/2” long stainless bolt & nylon lock nut. The supplied light bar mount L bracket was installed to the bar with the end facing inward toward the center of the bar for proper clearance.
The inside mount is made from 1&3/8” wide perforated, zinc plated steel that I picked up from Lowes. I used holes that were 3.5” on center (which equates to 4 full holes). I cut this piece to length and the top is attached in a vertical orientation to a 13mm bolt on the bottom of the radiator behind the bumper. The light bar is then attached to the 4th hole down. Similar to outboard mount, I bolted the light bar mount to the steel with the same stainless hardware. BUT - I had to attach the light bar L bracket mount to the light bar with the bracket facing outward which is the opposite direction of the other side so it fits properly. Once everything is snugged up tight, I needed to bend the perforated steel backward toward the motor so the light was focused toward the center of the vehicle. Thankfully this perforated material is strong enough for mounting but malleable to bend it backward to the perfect angle.
Last few tidbits - mount the bars with the wiring end toward the center of the vehicle so you don’t see and wires and then just run the harness up and over the front underneath the plastic shroud for the radiator then along the drivers side fender and up the Aux switch connection and grounding point. BTW - I cut the supplied wiring harness apart and only used the molex end and the red (+) & black (-) cables in the supplied techflex wiring loom and used zip ties along the way to prevent anything from coming loose or chafing.
I hope this helps others with this project!
antman92
Toronto
Edge
WuNgUn
Ontario Canada
2 door Squatched
Before & After
close up
low beams
Have you checked out the factory fog light switch thread?
You may have factory wiring there for fogs 👍🏻
noliveaxle
john
Riverside, Calif
2015 jku rubicon
This is a clean install. I like the way they fill in those openings. What I think is you should change to switch 3, 4, 5, or 6. You are using a 30 amp circuit while the one I listed are 10 amps. If you are not going to need the higher amperage somewhere else. Then the closest switch makes sense.
bytheway
Brice
Louisville, KY
WuNgUn
Ontario Canada
2 door Squatched
Bschurr
Bschurr
NY
Toccoa
Isuzu Rodeo Sport
low beams
Kinda looks like they would blind oncoming traffic. Is this just for off-roading? Looks perfect for that.
Bschurr
Bschurr
NY
Bschurr
Bschurr
NY
Thanks for the suggestion.
I wired direct to Aux 1 and left the purple wire on top of the grille in case I want to use it for something else down the road. Currently it’s the only Aux switch in use so the nearest to me makes sense at this time. Easy to change if needed.
Bschurr
Bschurr
NY
