- Adam
- Aug 30, 2021
- 545
- 6,117
- 7,032
- Lindenhurst, NY
- Website
- www.4x4TruckLEDs.com
- 2018 Raptor & 2021 Bronco Outer Banks
- Outer Banks
Kits are in stock. Orders in by 12PM (EST) ship the same day typically!
https://www.4x4truckleds.com/kr-off-road-arb-compressor-engine-bay-mount-for-2021-ford-bronco/
Use coupon code BRONCO6G and save 10%
If you've been looking for an easy to install mount for your ARB Single or Twin Compressor, look no further. KR Off-Road were the first in the industry to offer a commercially available ARB mount for the new 2021+ Ford Broncos. This system is 100% bolt-on and uses factory mounting points. With support for both 2.3L and 2.7L engines you'll be able to mount the ARB Single Compressor or the ARB Twin Compressor under the hood of your vehicle.
This mounting platform is the easiest system out there right now when it comes to mounting a compressor under your hood.
(PATENT PENDING)
FEATURES
Lifetime Warranty for the original owner.
OPTIONAL COMPRESSORS
ARB Air Compressors provide many advantages when exploring the great outdoors. Whether for inflating tires and camping accessories, running air tools, activating Air Lockers® or even re-seating a tire onto a wheel, there’s a model available to suit your needs. Designed to withstand the harshest environments, each ARB Air Compressor is individually leak tested, current draw tested and flow tested under heavy load at the factory before packing. For total peace of mind, all ARB Compressors come with a comprehensive 2-year warranty. To further increase longevity, ARB Compressors are also rebuildable, with spare parts readily available from our extensive network of ARB authorized dealers.
(PATENT PENDING)
FEATURES
- .135" (10 Gauge) #304 Stainless Steel
- Powder Coated Black Finish
- Designed & Manufactured in the USA
- 1 Bracket w/Support Bar
- 2021+ Ford Bronco w/2.3L Engine
- 2021+ Ford Bronco w/2.7L Engine
