FL Trucker
Ft. Lauderdale
F-150 Raptor, Fusion
More pics added
Ford Bronco Ford Bronco Raptor Drops Camo For a Revealing Look… Likely to Get ~450 HP 7528995_1261131877645279_7860697131533177138_n-
Ford Bronco Ford Bronco Raptor Drops Camo For a Revealing Look… Likely to Get ~450 HP 57681050_175321788072550_2500993301666237203_n-
Ford Bronco Ford Bronco Raptor Drops Camo For a Revealing Look… Likely to Get ~450 HP 57873485_119088727236073_1497478027887657356_n-
The Bronco Raptor, available in the summer of 2022, is rumored to be equipped with a V-6 EcoBoost engine upgraded from the base offering. If this rumor is true, and shares the same level of improved horsepower of the F-150 Raptor, you could expect somewhere in the neighborhood of 450 horsepower – not too shabby.
Sitting on 37s, the Bronco Raptor is taller from factory than any of the current 6-gen Broncos, and keeping with the trademark Raptor stance, much wider. Beefed up suspension and the iconic, and often copied front grille with the amber lights and more aggressive exterior styling. Source - bronconation
Ford Bronco Ford Bronco Raptor Drops Camo For a Revealing Look… Likely to Get ~450 HP 2022 Ford Bronco Raptor preview 5
Ford Bronco Ford Bronco Raptor Drops Camo For a Revealing Look… Likely to Get ~450 HP 2022 Ford Bronco Raptor preview 1
Ford Bronco Ford Bronco Raptor Drops Camo For a Revealing Look… Likely to Get ~450 HP 2022 Ford Bronco Raptor preview 3
Ford Bronco Ford Bronco Raptor Drops Camo For a Revealing Look… Likely to Get ~450 HP 2022 Ford Bronco Raptor preview 2
Ford Bronco Ford Bronco Raptor Drops Camo For a Revealing Look… Likely to Get ~450 HP 2022 Ford Bronco Raptor preview 4
Spooled
Republic of Texas
Raptor, Model 3
Instead of widebody fenders they just gave it even larger flares? 🤢🤢
Yikes
mjohnso3
Marc
Atlanta
FJ Cruiser
The Bronco Raptor, available in the summer of 2022, is rumored to be equipped with a V-6 EcoBoost engine upgraded from the base offering. If this rumor is true, and shares the same level of improved horsepower of the F-150 Raptor, you could expect somewhere in the neighborhood of 350 horsepower – not too shabby.
20 more horsepower than a 2.7 ? I would expect more.
Rivers90
Ben
Southern California
2 Door Base Sasquatch
This is looking good. I like that a lot of these parts should fit lower trim Broncos.
I think the flares look ok, and I really like how you could just buy a set and put them on a base Bronco. I wonder what else will be easily added from this.
I like the orange DRL.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Yikes
Both actually. The body looks like it's slightly wider at the grille edge.
NeoS281
Jared
Bellevue, WA
2024 Bronco
