jwoobs
Detroit
Finally home, so I'm going to write out some more details.
The Route:
Starting in Roscommon, we took the West Higgins Route to the Kalkaska Route. We took the northern loop about 3/4 of the way around before hopping off to take the Frederic Route back to Grayling.
All the Michigan DNR "routes" are 72"+ wide, so easy enough for all our vehicles to go through. There were some sections on the northeast portion of the Kalkaska loop that are very narrow cuts. I wouldn't have wanted anything wider.
The West Higgins Route has some very scenic elevated sections, and due to the late leaf drop this year there was still plenty of color.
The terrain was mostly sandy, there were the some dirt/mud sections as well. There was also some snow on the northern trails, plenty of puddles from snow melt, though about 1 foot deep at the most. These routes are groomed snowmobile trails in the winter, and we actually came across a grader in one section. So they are very well maintained.
The only two obstacles that presented any challenge were a fallen pine tree that required a bit of twist-ditch like diversion off the side of the trail, and a 2 foot boulder that would wipe out a driver's door if you slid to the left. Thank goodness the trail was dry in this section.
The Michigan DNR makes GPX files of the trails available on their website. I used Gaia GPS to import them, which works with both CarPlay and Android Auto. Despite some initial issues getting it to work with my Pixel phone, it worked great for seeing the trails. I paid for the premium subscription to get downloaded maps, and had no issues pulling them without cell service.
The Bronco
I have a 2dr Black Diamond, so it was plenty nimble for these trails. The General Grabbers were okay, but I also drove my friend's Wrangler, which had some Falkens off a Gladiator Rubicon. Those felt much better in the sand. I'm relatively new to off-roading, but I suspect the Grabbers are more for rock crawling with their much tighter tread block.
The GOAT modes are definitely noticeable, although I don't think they are strictly necessary. I started in Normal with 4H and T/C off. After a few stability interventions, I disabled that as well. The Bronco seemed to rotate better with a little throttle. If I tried to trail brake a little bit, it tended to push outside instead.
Later I switched to Mud/Ruts, which turned on 4H, locked the rear diff, T/C off, and set it to the ECO / Slippery throttle setting. I also tried Sand, which is basically the same except with the sport mode throttle setting.
Average fuel economy was about 16 mpg according to the cluster, but I didn't bother to validate that when fueling up. For comparison I've been getting about 17.9 on the highway.
We probably averaged about 25 mph over 80 trail miles.
I also used trail control on one of the descents, and it was excellent. The trail wasn't particularly slippery in that section, but it makes a controlled descent so drama-free. We also used it a bunch at Texas Off-Roadeo. Honestly one of the best trade-offs of being forced into the auto trans because I had the audacity to want heated seats in the mid-package.
When passing that boulder, I had no problem sticking my head out the window and seeing the exact position. Those thin doors make it very easy to get a feel for where your vehicle is. I can't say that I was conscious of the trail sights. I'd love to get a body color panel to delete them.
The 2.7L absolutely hauls the mail. 20-40 mph on the sand is a riotously good time.
Concerns about the Bronco:
  • Open crash bars: I had a ton of sand in these. When I shot the hose into them, the water seems to find some drain holes over the skid plate. Hoping most of the sand is gone. Might need to get some caps for the winter. Salt in there sounds like a losing combination.
  • Grunting during turns: I'm not sure if this was just the bushings loading up and squeaking, or the stability control going off. More investigation needed here
  • Nooks and crannies everywhere: Despite visiting two self-washes and a wash in the driveway, I'm certain there are still a couple pounds of sand on the frame, in the rear bumper, and above the wheel wells. The quick release fenders also love to trap dirt.
  • The rear wiper is small and cute, and not in a good way. I'd guess only about 1/3 of the rear glass gets wiped. Not going to be fun in the winter. Hopefully the defrost is kickass.
  • The single light stalk: About half the time I would active the turn signal while spraying the windshield. Not that bad, I just look like an idiot on the trails lol.
  • Black Diamond steel wheels: Although I prefer the look and also the strength of steel wheels over the alloys, they are almost impossible to clean from the exterior. The first spray wash I just hit them externally, not even thinking (or seeing) there might be mud trapped in there. After noticing they were unbalanced, I looked closer and saw the mud. So at the next spray wash I put the nozzle through the holes and also tried to get low and spray from underneath. I saw a lot of sand coming out, so I thought i would be okay, but they were still unbalanced. Finally I pulled over at a rest stop and just had to scoop it out by hand in the parking lot.
  • Hard top clunk: Not horrible, but there is a little clunk / rattle coming from just above and behind my left ear which will probably drive me to insanity over time.
  • 2dr storage space. I knew going in it was going to be a downgrade from my 4dr Mazda3 hatch, but it's a little worse than I thought. I wish the front seats slid forward about an extra 6 inches. I'll probably fold the seats flat when carrying a lot of stuff, but see the next point...
  • Rear glass requires tailgate to be fully open. You need about 4 feet of clear space behind the vehicle to get to most of the cargo area.
  • The bump for the rear seats. My focus and Mazda both had completely flat cargo areas. Might have to get a cargo drawer to level it out.
Versus The Competition
I drove the Wrangler and the Colorado ZR2 for about 15 minutes each as well.
My friend with the ZR2 swore the Bronco rode softer, while I felt his truck was actually better. This was on the freshly graded portion of the trail however, so probably not a good benchmark. I know a little bit about the DSSV dampers, and they are supposed to be top-notch. Obviously Ford thinks pretty highly of them to put them in the Bronco DR. I would rate the interior quality of the Colorado about an 8/10, and the Bronco about 7/10. I prefer the design, but the quality of the plastics in the Bronco seems lower. The Hero switches up at eye level are definitely better than the ZR2 ones down near the shifter.
The Wrangler felt lighter, like smaller 90's cars. The cabin was much smaller and closer; less room vertically and horizontally, though not cramped by any means. The Bronco feels much more like an F150 in terms of cab size. Didn't get to drive the wrangler on-road, but my friend says it's pretty floaty in comparison. I did think the Wrangler felt better over the sand whoops though. It did get a pretty rough side-to-side roll thing going on for a second that I never had happen in the Bronco. It felt a lot closer to my dad's old CJ Wrangler; not that it's a bad thing. In a weird way it seemed more connected to trail, where as the Bronco was more composed and isolated. Considering the Bronco is my daily driver, I'm okay with that trade off.
The Wrangler has the same crappy rear shock mounting point, but it wasn't an issue on this trail.
Apologies for the lack of photos and videos. I was intending to get a time-lapse off a GoPro, but didn't find a good mounting point and just decided to wheel instead.
The "Accessory Ready" Mounting point looks like it might 1/4-20 thread, so I might be able to just get a piece of threaded rod directly attach it.
EDIT 11/8: Added some more comments about the Wrangler.
Ford Bronco Mid Michigan - Kalkaska ORV route in Bronco Black Diamond 1636333555904
Ford Bronco Mid Michigan - Kalkaska ORV route in Bronco Black Diamond 1636333518922
This is a quick trip report to get my thoughts to paper, but I'll flesh it out a little more when I get back home.
The GOAT modes are nice, kinda like shortcuts to turn on 4H, turn off ESC and lock the diff.
The route:
The northern loop gets pretty tight, but nothing got too hairy. There was one cambered turn with a big-old door killing boulder in it, but we all got by it no problem. Plenty of scenic views on the southern legs.
Pros vs Wrangler:
-More head and shoulder room
-Tighter steering on road
Wrangler Pros:
- Felt lighter
- Rubicon take-off tires felt better on the sand
- seemed to soak up bumps better
Bronco Annoyances:
- The wiper button is hard to press, and about half the time I end up triggering the turn signal.
- Black diamond wheels trapped dirt inside, and they are hard to clean out
- Baby rear wiper
- Rear fender flare acts like a dirt shelf. Really need some oversized mud flaps available from Ford accessories. My friend with the ZR2 just chopped up some 18 wheeler flaps, so I'll probably just do that
- Open crash bars in wheel wells also collect dirt
Vs Diesel ZR2:
DSSVs are pretty slick. I'll be very interested to see if Ford drops the Bronco DR dampers as an accessory kit.
The Colorado probably had better interior finish.
Ford Bronco Mid Michigan - Kalkaska ORV route in Bronco Black Diamond DSC_3288.JPG
Ford Bronco Mid Michigan - Kalkaska ORV route in Bronco Black Diamond DSC_3286.JPG
Ford Bronco Mid Michigan - Kalkaska ORV route in Bronco Black Diamond IMG_20211108_072932
NorthShoreBronco
Steph
Canada
www.youtube.com
21 Badlands 2D, 22 BD 4 Door
Sounds like a fun day!
BigFootie
Wisconsin
Thanks for the honest and open review.
Area51outerbanks
Bill
Livonia, Michigan
2021 Bronco outerbanks 4dr area51
sounds like a great trip
I've done some of the north higgins lake stuff but want to do more
jwoobs
jwoobs
Detroit
Very cool trip, sounds like a blast. What PSI did you run your tires at?
Ran full 40 PSI. I'm sure that's part of the reason it was pushing on the sand. I even brought along my Makita inflator, but didn't bother to air down.
Because the trails get graded somewhat regularly, there weren't many whoops to worry about.
Yeah, I'm super glad I did it! Off-roadeo helped build my confidence a ton too; I wasn't afraid of anything these trails had to offer.
I was thinking of taking the Higgins route west to Cadillac on Sunday, but between checking out of the house and having a car full of crap, we decided to just take a trip to Frankenmuth instead.
Vellicate
James
2018 F150, 2014 Flex Limited
Love it up in that area, was supposed to head up to the Roscommon area on Sunday but had to cancel because of a sick kid. I have family that lives up there, been on a lot of those trails. Was hoping to break in the Badlands on some of them, maybe next weekend.
Mattwings
Matthew
Northville, MI
2021 Badlands Bronco
It's a great area. I have ridden my dual sport through most of it. That route should get even better if they open up the Grayling areas as proposed too. Most of the routes (that aren't also snowmobile trails) can actually get challenging with a bit of snow on them! Thanks for the write up and sharing your fun. Just a heads up if you haven't seen it, most of the ORV routes will close or be partially cut off Dec. 1 through April 1st if the proposed regulations get approved. http://www.legislature.mi.gov/(S(nt...g.aspx?page=GetObject&objectname=2021-HB-4535
jwoobs
jwoobs
Detroit
Oh, reading through that bill a little bit it's just so they can fine knobs who try to take wheeled vehicles on groomed sled trails $200. Doesn't sound like it closes any of the routes that aren't maintained snowmobile trails.
I'm okay with that!
hungrylikethewolf
Andrew
Detroit, Michigan
2016 Ford Focus ST (to be replaced by Bronco 2Dr)
Great write-up! Did the Black Diamond seem like it was suited for the types of trails you went on, or would you have preferred more equipment with the benefit of hindsight (Badlands, Saquatch, etc)?
We have a family cottage right on the trails up there, and I opted for a non-sasquatch 2.3L manual BD knowing that most of the off-roading I will do will be on trails like these throughout northern Michigan. Your trip is the closest thing I have found to my intended use case!
Mattwings
Matthew
Northville, MI
I'm okay with that!
The only problem is it shuts out most of the ORV routes, (only one of three conditions full size vehicles are actually allowed. ORV Routes, 5 Scramble areas and State Forest "Roads"). I agree that we should stay off groomed trials, but you cant even cross a trail the way the bill reads. Most of the northern sections aren't passable by a full size vehicle in winter anyway, but on the East side, it varies quite a bit with temperature and snowfall. St. Helens is a good example. Look at the Scramble area and then look at the Snowmobile trials, it effectively cuts it out of full size use as soon as the groomers start. It's probably not a problem as most of the seasonal roads become pretty good "trails" in the winter, but it can get very confusing where routes, trails and roads zig zag across each other.
jwoobs
jwoobs
Detroit
The BD felt plenty capable on these trails. It was the perfect width too, I think Squatch would actually have been a hinderance. I'd rather have the extra nimble-ness instead of the extra ground clearance. That 4 door Wrangler didn't have any issues either, so length wasn't a problem.
Airing down probably would have helped with the pushing/sliding I was experiencing in turns, and if not I'm sure there are better sand tires out there. I'm just going to wear the factory Grabbers down though, no need to rush out and get something different.
No need for the front locker, though maybe if the trails get really soupy it could help. I don't really plan to go out in those conditions anyway.
The swaybar disco wouldn't have helped either. These trails in particular a pretty flat, I never ended up hanging a wheel in the air at any point.
The sand may have stained my paint though, so I would recommend a good high quality wax or ceramic coating before heading out. Going to see if I can clay bar this brown spot out, then I'll be looking into ceramic coating myself.
VelocityBronco
E
Bronco Badlands, F-150 FX4, Explorer Platinum
I live in the Cadillac area so it's nice to see a write up in the area.
Where about in Cadillac area? I am in Cadillac West and did some light 2-tracking this weekend. Lots of area by Lake Olga. Found a nice hill climb in Meauwataka area yesterday while out with my kid.
I want to find more trails/routes to explore in the area, so thanks @jwoobs for this route. That would make a good day trip with the family to run up to Grayling area to explore.
