De Brus
De Brus
Washington state
'14 HD 1200, '66 IH, '62 VW
I am interested in seeing if this can be used to tap a reverse trigger wire as well for aux reverse lights.
Absolutely. If it can power trailer reverse lights, you can run led aux lights also.
chtucker
Kirkland, WA
FJ Cruiser
I would put a posi-tap on the Curt wiring to a relay to drive some reverse lights, I would probably add in a diode so that the lights can be triggered by the reverse lights or an Aux switch. I am just getting soft about putting a positap on factory wiring... Though I usually drill bigger wholes in new cars, they are not mine.
grtharris
Grant
Skiatook, OK
Outer Banks 4dr, 2008 Mustang GT CS (Wife's), MH
Guys, don't read something into this that's not there, it is a four way device. From there web ad.
"4-way flat output connects tail lights, brake lights and turn signals"
chtucker
Kirkland, WA
FJ Cruiser
Agree 100% but it looks like there are wired that are ran straight through for other functions.. I am hoping that one of those wires is a reverse light. I understand that the 4 wire doesn't have the reverse light.
chtucker
Kirkland, WA
FJ Cruiser
Why no 7 pin connector?
Because it needs a bunch more stuff (charge wire, reverse wire, brake wire) you could add the charge wire and brake wire to a brake controller yourself pretty easy. Most trailers anyone would be towing with a Bronco, likely don't have reverse lights.
grtharris
Grant
Skiatook, OK
The last sheet of the instructions shows the actual wiring. The extra red wire is for a two-wire system.
mmorgan
South Carolina
2023 Bronco
I was looking at the instruction sheet. Did anyone see where the red fuse wire was used/installed?
OK
So the module is getting power from the wiring harness and does not need a separate power supply?
grtharris
Grant
Skiatook, OK
mmorgan, the red wire and fuse connect to the battery and splice into the black wire. There drawing color is a little off. This is the power for the system.
The red wire going to the harness is for a two wire system (brake and turn signal separate).
72BroncoSand
PNW
72 Bronco, 77 f-150, Jetta Tdi, 1ton
How can I order? Take my money
