Administrator
Administrator
Staff member
Doug
Bronco6g.com
TSB 21-2339
TECHNICAL SERVICE BULLETIN
Soft Top Roof - Paint Scratches On Sports Tube
Issue:
Some 2021 Bronco vehicles equipped with a soft top roof may experience paint scratches on the sports tube due to contact with the soft top roof frame during the open and close operation. This may be due to a lack of protective measures installed on the soft top roof frame. To correct the condition, follow the Service Procedure to apply protective hook and loop fasteners to sections of the soft top roof frame.
Action: Follow the Service Procedure steps to correct the condition if the vehicle meets all of the following criteria:
• 2021 Bronco
• Factory soft top roof
• Paint scratches present on the sports tube due to contact with the soft top roof frame
Parts & Service Procedure: [see attached document]
bytheway
Brice
Louisville, KY
LMAO! You MUST have paint scratches to have them add felt to prevent paint scratches.
Designkid
Kris
New Jersey
2021 Bronco Badlands
Pretty sure this is already being done either at MAP or my dealer. My August delivery already had this done.
VoltageDrop
Fidalgo Island, WA
23, 69 Bronco
Short version of TSB:
IF NOT Fuzzy_Velcro
DO Fuzzy_Velcro
Else
DO Beers
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Would be interesting to hear from others as well who recently received their soft top Bronco's to see if it was done at MAP. I would think they would, if they issued this notice, but you never know.
CFLBronco
1976 Bronco
Yep - just checked my September 2 build and this was already in place.
Although, in the Florida heat, the adhesive seemed fluid and the velcro pieces could easily move around, so it will be something to check periodically to make sure none of them have come off.
604Bronco
British Columbia
www.bronco6g.com
I would hope there's an automotive-grade adhesive they used. I use 3M double sided automotive tape on my dash camera. It cooks on my windshield in the Summer, and never an issue. If this did become an issue though, that'd what I'd use to stick it back in place.
ChrisD
2021 Ford Bronco Badlands, 2021 Lincoln Corsair
Ha, OK, I'll get that TSB done on mine. I don't have paint scratches, I have paint chips. Or I could just velcro it myself. I love putting velcro on things. In most cases, I'm slapping velcro in places I think I will want to attach something.
I wind up slapping velcro on, temporarily putting something in a place, then leaving the pile (soft) part there in case I want to put something else there later.
It's modular, kind of like the Bronco. LOL
JohnnyBronco
Pennsylania
X4
So is unhooking velcro halves a requirement of top opening or are they using only one half of a two part system? I hope they are using the soft part
Garemlin
Delaware
Even if mine has this done from the factory, I think I am still going to do a layer of PPF for added insurance. Never know if those pads will fall off without being noticed.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Probably a good place to add this. For $25 - already cut to fit.
Roll Bar PPF
dwbronco
Manchester, NH
2018 F-150 King Ranch
You'll want to place the PPF over the velcro. That way, you can make sure the velcro is protected, too.
