2025 badlands camera restriction
Benjamin
Good afternoon,
i’m considering installing the Westin XTS front bumper and brush guard with a super winch 10 and I’m curious if anyone has experienced or noticed any blockage from the factory mount camera on a 2025 Badlands with this configuration. My concern is the bumper sticks out a little bit farther because of the winch mount so is the camera adjustable up a little bit or is it just going to be a restricted view?
Dylan pasty
Dylan
Portland Oregon
Bronco 2 door
I’ve got a 23 badlands. And got a aftermarket front bumper. And depending on the bumper your wanting it will block it or slightly. They make relocation kits for the camera. But the camera will be out of sync kind of but still works great. If you got cruise control ACC you might need to relocate it. Also my sensors go crazy over nothing so I have it disconnected. Hope this helps
Benjamin Green
Benjamin
Sorry. 25 badlands!!!!!
thanks Dylan. Did your new bumper have the cut outs for the sensors?? The Westin does. I’ll research the cruise control issue for sure
Dylan pasty
Dylan
Portland Oregon
Bronco 2 door
Yes it did have pre cut sensors. Here’s a pictue I found of my bumper. You can see the camera is right under the pull bar. I’m pretty satisfied with what I’ve got
Ford Bronco 2025 badlands camera restriction IMG_3490
