2023 Bronco MIC Top Leak
BR0NC0M0M
Jennifer
'98 Mustang; '18 Edge Sport; '23 Bronco
Anyone else having issues with their 2023 MIC Roof leaking? It’s rained pretty heavily today. Can’t quite make out where the leak is coming from. Possible mid roof panel where it meets rear/trunk roof panel? Haven’t had either section off yet.
I was parked on an incline in my driveway. I only realized I had it when I turned a corner and my kid complained the car was leaking on him. 😅
Ford Bronco 2023 Bronco MIC Top Leak EF2DE74C-BCC4-4C82-9BDE-2712B23096C3
Ford Bronco 2023 Bronco MIC Top Leak 1BD4C744-B0EA-442B-AA17-4EE75FA04298
Ford Bronco 2023 Bronco MIC Top Leak C7DDFD57-1A50-442F-906A-AB13FAD31171
Ford Bronco 2023 Bronco MIC Top Leak 18EDBE98-963D-475D-83BF-2832E500842E
Ford Bronco 2023 Bronco MIC Top Leak 0B87CF54-B802-47BD-B21C-2E73B1BFE1B6
Hopeless Diamond
JR
Chumstick, WA
F350/2dr Rubicon/'96 4R/'02 Silverado 1500/'22 Badlands
Yep, had a similar leak in my'22, not as bad though. They ended up replacing the seal on the on the back clam shell and so far so good. Was surprised it was available, just had a little shipping delay.
Had posted asking about it on the forum here but didn't get much response. The Ford account did reach out about it and set up a case #. They were all over it, making sure the dealer was working on it. They kept following up with me and them, almost to the point of being a bit excessive about it.
BR0NC0M0M
BR0NC0M0M
Jennifer
Thanks for your reply! I looked up your post and it was helpful too. I dried everything up …roof liner didn’t seem wet. Do you have one? Did you notice if it was wet or have any issues with it after the leaking issue?
My Bronco is getting seen for another issue on Mar 3rd (earliest the dealer can get it in) guess I’ll add this to their to do list lol.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Good morning. Would you please send over a private message with your VIN and dealer info so I can look into this leaking concern on my end? Thanks!
KFreakin
Kenny
Tennessee
23 Badlands
My my23 bronco did the same thing but near the front passenger A-Pillar. Happens when slightly parked at an angle. Dealership had it for nearly 14 days and still no fix :/
Hopeless Diamond
JR
Chumstick, WA
Check the alignment of the front 2 panels in the center. If the center clamp isn't tight, or they don't meet correctly, water can get in to the windshield channel and run over to one of the A-pillars.
tambrico
Trevor
New York
Niner Air 9
Yes. They investigated and found that my two front panels were missing a "centering pin" from the factory. They replaced it and redid the seals.
DBC Offroad
Sean
Reno, NV
www.youtube.com
'23 Raptor
Just discovered mine was leaking today too. 312 miles and 2 weeks of ownership. Dripping from the passenger A pillar. Not sure where the actual leak is.
JKJ6
Nashville TN
2022 Ford Bronco
Mine leaks down the passenger side A Pillar. I called the dealership last week and they told me a "lea specialist" would be giving me a call back to set up an appointment. I still haven't heard back.
SquatchErik
Erik
2005 Jeep Liberty Limited CRD
+1 for driver side A pillar leak on 2022 Wildtrak MIC top, just made an appointment with dealer to investigate.
Ford Bronco 2023 Bronco MIC Top Leak PXL_20230619_233540073
Ford Bronco 2023 Bronco MIC Top Leak PXL_20230619_233536102
Lankyhank888
LankyHank
TX
youtube.com
2025 Ford Bronco Raptor
Did you have better luck than me? What was the problem?
