2021 Bronco height?
ronstar
Ron
Illinois
F-150, Jeep JL
The specs for every model on Ford's website show the height to be 73.0" for the soft top. How can that be when some models have 35" tires and the base has 30" tires?
I'm trying to figure what to do to make sure that I can get it into the garage - with an open door opening of 79.5".
Looks like I can clear the soft top with a little room to spare, but Ford doesn't give the height for the hardtop. I assume hardtop is a little taller. I'd also like to get a roof rack. That may not be possible.
And the radio antenna. No way is that thing going to clear my garage door opening. I had to cut about 3" off the antennas of my last 2 F-150's. The Bronco looks like it would need far more than 3" cut off.
I assume that the radio antenna height will be a problem fro everyone with a 7' tall garage door. Is there a better solution than cutting off part of the antenna?
I may need to look into getting a few more inches of garage door clearance.
kodiakisland
Arkansas
Ford Bronco 2021 Bronco height? 1596386580844
Should answer all your questions near enough except antenna. Mine are all flexible and has never been an issue going in and out of a garage.
ronstar
ronstar
Ron
Illinois
F-150, Jeep JL
Perfect - Thanks!
Desert_6G
Phoenix, AZ
Ranger
I'm in your name situation. My garage door is also 7' and if I can't fit it in my garge with a 2-3" lift on 33" then I'm not pursuring to purchase a Bronco. I was compare the height of my Ranger with a lift on 33". I think the height will be fine. The hard top is likely add 1-2" compared to the soft top. And i belive the height given by ford applies to the non lifted bronco on standard tires. you can always buy a stubby antenna that is only 2-3"; if the bronco has a antenna. I don't remember seeing what kind of antenna it has.
USASAIL
St Petersburg, FL
Volvo S90, Chevy Suburban, Base 2Dr
Use the Wildtrack as a Sasquatch Model (It basically is pre-sasquatched) 4 Door 75.3" Plus if you add the rack 3.4" = 78.7" A standard garage door is 7' (84"). That gives you 5.3" before you are scraping concrete.
OmahaKevin
Kevin
Omaha
2012 Mustang GT, 2023 OBX
Has anyone seen exactly how much height the hard top adds. I've got a 78" garage door opening so every inch counts.
BroncBro
2019 Tacoma 4x4
It’s not possible until they actually build a real one. That’s not going to happen until next March. It’s a close estimate until then
AZHUND
2020 RAM 1500 5.7L 4x4, 2018 Wrangler S 3.6L
Recommend actually measuring your door before assuming that. I have a 7' garage door, but actual opening is just over 80" after you account for the concrete 'lip' and the bottom edge of the door when you have it open.
bbqbronco
Austin, TX
EG Badlands
If your vehicle not fitting in your garage after YOU add a lift is a deal breaker, I'd say you prob don't really want a bronco that much.
Locked-n-loaded
Kevin
SoCal
www.socalfj40.com
'74 Toyota FJ40
In a standard 2 car garage, I drive in my FJ40 with 35's + a suspension lift & a custom light bar with KC lights that all stick up above roofline.
I'd be shocked if the stock rig wasn't verfied to fit in a common garage (sans roof rack, lights, gear).
Ford Bronco 2021 Bronco height? overlook-01
On a side note, I'd instantly remove the antenna & cap it or go to a stubby. I loathe terrestrial radio & will never listen.
Desert_6G
Phoenix, AZ
Ranger
I don't need a Bronco. I'm perfectly happy with my current Ranger that fits in my garage nicely. I don't want my vehicles left in the driveway exposed to the elements getting sun baked every single day.
zaki
'19 Lexus LS 500;'94 Acura NSX;'13 Landcruiser
No one really “needs” a Bronco or a Raptor or a 911 etc etc. It’s purely a matter of lust;)
You either lust after it or you don’t.
Fuzion2Bronco
Asher
Base Sasquatch
Ford Bronco 2021 Bronco height? hatersgonnahate
Cencal Bronco
Wayne
Merced, CA
The hard top is shorter. I think it' an 1.5" - 2" shorter if I am remembering correctly.
