2021 Bronco Camburg 1.25" Performance Uniball Upper Control Arms CAM-110213
Stage 3 Motorsports
Joel
www.stage3motorsports.com
2021 Bronco Badlands 4 Door 2.7L Ecoboost
As part information is being released they are being added to our website daily, today we have the Camburg Uniball UCA's listed below.
Ford Bronco 2021 Bronco Camburg 1.25" Performance Uniball Upper Control Arms CAM-110213 1630449326958
2021 Bronco Camburg 1.25" Uniball UCA Features:
  • New, durable design with uniball caps
  • Immediate upgrade over weak factory ball-joints
  • Built around a 1.25" FK with PTFE liner to help resist wear and tear
  • Polyurethane frame pivot bushings with grease-able zerk fittings
  • Bolt-on replacements for stock
  • Adjusts your Bronco for proper alignment and curve geometry
  • Requires 1-3" of leveling
Unlock Your Suspension's Full Potential
With the new 2021 Bronco coming out hot off the press, we know that the enthusiast in you is dying to create your own build. In terms of performance, suspension should be one of the very first major modifications you make to your Bronco. Slapping the most capable struts and shocks on, however, is only half the equation. Any well-versed operator knows that it will take intentionally designed upper control arms to reap the benefits of any suspension package. Thankfully, Camburg has developed computer-aided designed and manufactured (CAD/CAM) Performance Uniball Upper Control Arms for this very reason. Specifically designed for suspension kits that offer your 2021 Bronco 1" to 3" of lift. With these upper control arms you'll be able to take your build on tougher and longer off-road excursions without encountering any issues. Incredibly Durable Construction, Incredibly Proper Wheel Travel
Camburg's Performance Uniball Upper Control Arm's were built with 1.25" PTFE-lined uniball bearings to allow your 2021 Bronco to perform better and longer under extreme conditions. You'll never have to cut an off-roading day short when you rock with these tank-like UCAs. Built with more caster and with an adjusted camber curve, Camburg's uniball upper control arms correctly align your Bronco while increasing its overall handling characteristics. These UCAs come equipped with a billet aluminum cover to prevent dirt and other debris from ruining your uniball. Using an o-ring seal, the cap is press-fit to the UCAs and adds years to its lifespan. A 1.56" thick wall wraps around the tubing and is covered in a steel gray powder-coating for extreme durability. In essence, with Camburg's Performance Upper Control Arms you'll be in possession of arguably the most capable and durable UCAs for 2021 Broncos available on the market. All necessary hardware is included and everything will be ready for you to install upon arrival. Innovative Design Process
Camburg took the designing process of these UCAs to the next level by using a FARO laser scan arm to fully model the OEM parts and frame to create the best possible fitment for your 2021 Bronco. Manufactured in-house (USA), Camburg CNC laser cut and bent the tubes which are then MIG welded before being sand-blasted and powder-coated. Production in-house is rare to find these days when 3rd party contractors will sell their souls to get any type of production contract. Don't take it for granted that Camburg has complete and utter control of the entire process that goes into manufacturing these UCAs.
Fitment:
  • 2021 Bronco 4-Door
  • 2021 Bronco 2-Door
  • Will NOT fit Bronco Sport models
Requires at least 1" of front lift: these UCAs require at least 1" of leveling due to their caster and camber changes. The max lift for these UCAs is 3"
Backspacing Requirements: these control arms require a wheel with a maximum of 5" of backspace in order to clear a 12.50" wide tire.
Stage 3 Motorsports
Stage 3 Motorsports
Joel
So they don't fit stock wheels?
Somehow i missed your reply. They fit stock wheels but not with a 12.5" wide tire. Those are very common fitment notes with aftermarket control arms.
TXNavy
Christopher
Spring, TX
GMC Yukon XLT 1500 4x4, Jeep Liberty Limited
So not the -55 offset on BL and below trims? Or not even on the SAS -18 Offset Wheels?
TRMFAM
Rob
OK
Hmm...what is the backspace on the FE/WT/BL wheels? I have read they are +30 offset but I have not seen the backspace measurement.
Stage 3 Motorsports
Stage 3 Motorsports
Joel
Just got a stocking order of these in, they are on the shelf and ready to ship!
Frank
dweskamp
Dan
Missouri
2016 GMC truck
Stock wheel offsets
Stage 3 Motorsports
Stage 3 Motorsports
Joel
And again just to clarify, these will work with factory wheels, the notes on backspacing are for you to fit a 12.5" wide tire.
Stage 3 Motorsports
Stage 3 Motorsports
Joel
These are in stock, for anyone in the market shoot me a message.
Rick Astley
Up Doug's ass
d
Just waiting on a VIN to start opening the pocket book for mods.
Aftermarket UCA's were a fantastic upgrade on my track car (Mitsubishi Evo 9), can only imagine the improved geometry while off-roading being valuable as well.
Brandon Miller
Pollock Pines, CA
2022 Badlands
I am unable to get caster in spec, is that expected? Adjustment pics shown because I honestly don't know how those work, they appear maxed out but this is what I got back from the alignment shop...
