- Dave
- Aug 25, 2020
- 24
- 3,126
- 11,881
- Hanging Rock, North Carolina
- 19 Z71, 06 VTX1300, 94 Cobra, 21 BL Bronco 4dr.
- Badlands
I have a build week, expecting it hopefully by the end of the year. I've come to the conclusion that selling my TJ to apply those funds to the Down payment makes more sense than keeping it to drive once in a while. So it's up for sale here and locally.
Details:
2001 TJ, 4.0 5 speed.
Prior owner installed/work done about 7K miles ago:
-4" Skyjacker lift
-Energy Suspension 1" lift body bushings
-Gas tank skid plate and new straps
-Dynomax Cat-back exhaust
-Fender Flares, side markers
-Hi-Lift Jack and mounts
-all 3 parking brake cables
-Energy Suspension Sway bar bushings and oversize rear sway bar added.
-Terraflex Slip Yoke kit
-Double Cardan Driveshaft.
-Stainless Tailgate bushings and pins
-Dana 30 Spartan locker
-Quick Release top box knuckles
-D44 Rear disc brake conversion with new discs, pads, parking brake shoes
-Rugged Ridge entry guards
-Bestop Trunk security enclosure
-Poison Spider Hood Louver panel
-Rock Sliders with steps
-Both Front fenders (sealed underneath and behind mounting seam)
-Rugged Ridge locking lugs
-Kenwood Stereo, Fosgate amp, Kicker sub, new dash and Soundbar speakers.
-Rear axle bearings and seals
-G2 aluminum Diff covers
-Upper control arms both front and rear
-Engine replaced with one that had @95K (no knocks, smoke, etc.) Water pump, oil pump, rear main all new)
-complete steering system replaced with all new MOOG components
-Brake booster, Master Cyl, brake lines and hoses replaced with new.
-Front wheel bearing assys.
-Belt, idler, tensioner pulleys.
-Radiator and all hoses
-Trans mount
-Both front axle U joints
-Oliver's front driveshaft.
-Tailights
-MOOG pinion angle adjustment kits front and rear
-All new Fluids
-Transfer case shift cable to replace unreliable and clunky linkage
-Windshield light bar mounts
-52" LED light bar and pod lights w/ mounts
-A/C and heater control switch
-Multifunction switch on column, new ignition cylinder.
-Rearview mirror
-Spare tire relocation bracket
-4 Mickey Thomson Deegan 38's in 33X12.50
-4 new Black Rock steel wheels 15X10
-Underhood light assy
-Outside mirrors
-Brute Force clutch, pressure plate, throwout bearing, flywheel, and slave cyl.
-HD Steel front and rear bumpers with receivers on both.
-Reese Tow Bar
-Rhino Lined Tub
I have added since May:
-New O2 sensors (was giving bank 2 code, still occasionally does, but I clear it, does not affect the performance)
-LED Headlights With turns in the halo ring
-LED blackout parking lights
-Grab handles for entry
-Bedlined fender flares
-JKS front swaybar quick disconnects
-Dupont chromabase Chameleon base (over a Galaxy Grey base), House of Kolor clear coat.
-Rugged Ridge neoprene seat covers front and rear.
-LED Rock lights
-Switch panel mounted under the column with 4 pre-wired open switches for future expansion.
-New upper soft door halves
-Aluminum Hood latches
Drives great, runs great, very capable and fun. Really turns heads. Zero frame rust, underside looks great.
The lower steps do un-pin and swivel up out of the way. I figured this out AFTER the trip offroad.
Asking $12K.
Will text/email whatever extra pictures you want.
EDIT:
Added/changed since listed:
New Steel flat fender flares
New passenger side fender
New Adjustable control arms lower front
New tie rods, steering gear, drag link, pitman arm, radius bar.
Had a minor bump up into the rear of another car when they stopped in the road ahead of me for a dog.
Fender took the damage, and I knew I had one tie rod get messed up. I went ahead and replaced it all to be safe, repainted the whole Jeep again due to the color, added the steel flares. No other damage, and had it lined up at a Jeep specialty shop, everything checked out and it runs/drives/ looks as good or better than it did.
NO Frame damage.
Details:
-4" Skyjacker lift
-Trans mount
-Tailights
-All new Fluids
-Rearview mirror
-Outside mirrors
-Reese Tow Bar
-Rhino Lined Tub
-LED Rock lights
Asking $12K.
EDIT:
NO Frame damage.
