2 NEW BUMPERS FROM ADD - LETHAL PERFORMANCE
LethalPerformance
Jared
South Florida
www.lethalperformance.com
Hey All,
We just added 2 Brand New Bumpers and a matching Skid Plate to our Addictive Desert Designs line up here at Lethal Performance.
Bomber Front Bumper (Baja) F230194120103
Ford Bronco 2 NEW BUMPERS FROM ADD - LETHAL PERFORMANCE 1640029154522
The Bomber is a tight fitting front bumper for the new Bronco, that follows the contours of the body perfectly. At the center of the bumper is a satin black aluminum panel that frames 3 mounting points for Baja Designs LP4 lights (also available with Rigid Lighting). At the sides of the bumper are mounting points for cube lights, framed by satin black aluminum panels. The Bomber is constructed from modern plate steel, and finished in a hammer black powder coat. The aluminum panels are finished in a satin black powder coat.
Ford Bronco 2 NEW BUMPERS FROM ADD - LETHAL PERFORMANCE 1640029154570
The approach angle of the Bomber is improved over the factory bumper, and it also provides higher clearance. The OEM parking sensors are incorporated into the design of the bumper, and the tow hooks are allowed to remain underneath the bumper. There are 2 heavily reinforced clevis mounts that take 3/4-inch D-ring shackles for recovery options. We offer an optional 3/16-inch vented aluminum skid plate that provides superior protection over the factory plastic skid plate. An Adaptive Cruise Control Relocation Bracket is also available, which allows you to retain full functionality of the feature. As always, this is fully bolt-on and Made in America.
Ford Bronco 2 NEW BUMPERS FROM ADD - LETHAL PERFORMANCE 1640029154605
FEATURES
- Modern plate steel design
- Optional full 3/16" aluminum skid plate
- Optional adaptive cruise control bracket
- Mounts for 3 Baja Designs LP4 lights
- Side mounts for 2 cube lights
- Retains OEM tow hooks
- Retains OEM parking sensors
- Fully bolt-on
- Made in America
- Requires Adaptive Cruise Control Relocation Bracket for adaptive cruise control equipped vehicles
- Hammer black powder coat finish
- Satin black powder coat panel finish
- Mounts for cube lights on sides
Check it out here below:
Addictive Desert Designs F230194120103 Bomber Front Bumper (Baja) (2021-2022 Ford Bronco)
Addictive Desert Designs F230194130103 Bomber Front Bumper (RIGID)
Ford Bronco 2 NEW BUMPERS FROM ADD - LETHAL PERFORMANCE 1640029154637
At the center of the bumper, is a satin black aluminum panel that frames 3 mounting points for Rigid 360 6-inch lights (also available with Baja Designs Lighting). At the sides of the bumper are mounting points for cube lights, framed by satin black aluminum panels.
Ford Bronco 2 NEW BUMPERS FROM ADD - LETHAL PERFORMANCE 1640029154667
- Mounts for 3 RIGID 360 6” lights
Addictive Desert Designs F230194130103 Bomber Front Bumper (RIGID) (2021-2022 Ford Bronco)
Addictive Desert Designs AC23008NA03 Bomber Front Bumper Skid Plate
Ford Bronco 2 NEW BUMPERS FROM ADD - LETHAL PERFORMANCE 1640029154697
The Bomber Front Skid Plate was designed to replace the plastic OEM skid plate, and flow with the contours of our Bomber Bronco Front Bumper. It is constructed from 3/16-inch aluminum alloy, and finished in a satin black powder coat to protect it from rust. This skid plate can protect the front underbelly of you Bronco in a way that plastic can not. As always, this is fully bolt-on and Made in America.
Ford Bronco 2 NEW BUMPERS FROM ADD - LETHAL PERFORMANCE 1640029154725
- Full 3/16" aluminum skid plate
- Fully bolt-on
- Made in America
Check it out below:
Addictive Desert Designs AC23008NA03 Bomber Front Bumper Skid Plate (2021-2022 Ford Bronco)
Have questions or want to get something on order? Feel free to reach out to me or any one of us on here, shoot us a call at 561-753-8105, or shoot us an email at [email protected]
Joe Rocchio / [email protected]
877-2-LETHAL | lethalperformance.com
Ford Bronco 2 NEW BUMPERS FROM ADD - LETHAL PERFORMANCE 1640029154749
Draughon
Daylon
Dallas
BMW 4-Series
I like the look....but for $3800+tax with the lights added...imma have to pass.
bronco_boy
eric
Saskatchewan
kia soul
Hey, love the bomber front bumper. Couple questions tho:
- any option to have 2 cube lights on each side instead of 1?
- any updates on the design around the 3 main light section? Looks off where it just has a sharp bend in the sheet metal panel holding the lights and comes under on the front: should just be a section of metal plate holding the 3 light pods that pops into a hole in the bumper like you do with the Stealth Fighter version.
- what sort of lead time is it right now?
Thanks,
E
