2.3 EcoBoost vs 2.7 EcoBoost - Poll
  • Total voters
    1,262
KidGorgeous
Mass
2017 Tacoma
As long as the 2.7 isn't an astronomical upcharge, I'm in. I believe it's a $1000 option on the F-150.
Do this poll again after pricing announcements for more accurate results.
I wouldn't be shocked if altogether it came out to about 3 grand if you're going from a 2.3 manual to a 2.7 auto.
Roughly $1000 for the 2.7 (as in the F150) plus another 2k for the transmission (at least that's the up-charge on the Mustang).
Spooled
Republic of Texas
Raptor, Model 3
For sure. My comment was made before we knew the 2.7 was auto only
Phil_68w10
Phillip
Houston Texas
2016 F150 XLT
I gotta go with the 2.7 for that added torque. Hoping to utilize those GOAT modes, mainly sand and mud since I live in Texas.
BroAD
Adam
Illinois
2012 Ford F-150
One of my biggest concerns regarding the 2.3l versus the 2.7l is the type of injection. The 2.3l has direct injection but the 2.7l has both direct & port injection. And, since the M/T only comes on the 2.3l engine, it makes this decision even more challenging.
With direct injection engines only, there is a huge concern for carbon deposits on the valves. Since direct injection only injects fuel into the cylinder, it doesn't "clean" the valve stems which causes buildup.
This is big problem with my 2012 F-150 Ecoboost 3.5l engine where I have to spray CRC Intake Valve cleaner into the engine every oil change to ensure I don't have to use an aggressive technique such as walnut blasting to remove the carbon deposits. With a direct & port injection engine, fuel is both sprayed directly into the cylinder as well as the chamber before the valves.
Jason from Engineering Explained has a great video on the differences between direct injection and direct & port injection:
Why New Cars Are Using Both Direct & Port Fuel Injection
Hope this helps everyone or just adds more questions to your overall decision.
Mopar2Bronco2021
Houston
2018 Dodge Charger RT 5.7L
2.7L because:
Power and torque. It’s hard to turn down 400 lbft of torque. That extra power will help through some mountains down in southwest Texas running through Big Bend. I like being able to pass people easily too. Especially on 75+ mph roads.
aabsalon
Alan
Sacramento
Toyota Tacoma
2.7L because:
Doesnt the 2.3 get better miles per gallon? I am going for the 2.3 because of the manual transmission.
Mopar2Bronco2021
Houston
Most likely but I bet highway mileage won’t be much different. Probably about 3 mpg difference, but even if it was 5 I wouldn’t mind for the extra torque.
toymaster
Leonardo
Wyoming
2023 Badlands
I'm ordering the 2.7. I have a 2018 3.5eb out of a burned F150 (seal belt issue) with less than 10K miles on it. Got it for another project but will investigate putting it in the Bronco.
BigLig
Russ
F150 FX4
My wife has a 2017 Ford Edge Sport with the 2.7. We love it! Have had zero issues with it. The 2021 Bronco is rated for more power, so I’ll sold!
BroAD
Adam
Illinois
2012 Ford F-150
I’m not sure you’ll get better mileage with the 2.3l and the manual since they are gearing the Bronco down to get a better crawl ration. With gears that low and the smaller engine, RPMs are going to be higher on highway drives.
CMar
Tampa, FL
2010 Nissan Pathfinder
2.3 with tune if towing capacity stays the same for the two.
2.7 if towing capacity gets bumped to 5K plus.
Spudly
Brett
Denver
GX460, Gladiator Overland, RX350
2.7... though @Ford needs to up their game and the HP. 310 seems LOW for the 2.7. Torque seems spot on though.
