PREMiERdrum
OH
2013 Flex, 2016 Explorer, 2021 Bronco
Enough about bad roofs, late scheduling, and multi-week gate holds to check the roof panels, okay? The fine men and women of MAP are ramping up at an exciting pace to get as many of your builds out the door as possible.
The current pace of production is seeing nearly 900 units daily roll off of final assembly as we sit just 2 weeks away from "full blend" line speed. That 900 figure is split between Bronco and Ranger, currently running about a 60/40 split. Bronco's body shop has been pushing out as many as 300 rigs per shift, as they are running ahead of final a bit on speed. Units are only going to paint when there is room for them on final after, so there will be some ebb and flow here.
We've all been let down by the issues surrounding the MIC tops - my own included - and I have to believe that there is a fix in the works. All I can say for certain is that issues are being documented thoroughly and I expect some customer-facing movement on this soon.
As you've seen, production mix for the coming months is shifting outside of demand for hard tops (and all 2 door units). There was optimism in the last 6 weeks when output at the Plymouth plant ticked up a bit, but the multiple issues with delivered roof units has popped that balloon quite quickly. I can't say for sure what the final mix will be, but dealers are being asked to program retail stock builds (all 4 door soft tops, mostly base and Big Bend trims) so that MAP has a pool of backup builds in case they run out of buildable units. They will NOT build appreciable stock units IF there are buildable customer units in the queue. It's just a matter of what they're able to build.
IF you're lucky enough to get a hard top Bronco delivered, document the heck out of your roof at delivery. Take pictures of the entire inside and outside in detail. Note any inconsistencies - however small - so the dealer has record of it for when a solution becomes available.
The more I hear from my folks and spend time watching how my roof is reacting to everyday use, it's becoming sadly apparent that the design might only work if manufacturing were 100% perfect.. and even then it's iffy. Specifically, the raw edges where all 3 layers are cross-sectioned is just begging for material loss from the core (mine has happened in a pretty dramatic fashion in the last 3 weeks), leaving little cavities where water can accumulate and cause havoc when the weather shifts.
Annoying roof issues aside - that I'm confident Ford will address - these rigs are sweet. They're fun an engaging to drive, they're comfortable to live with, they do what you ask them to without any protest, and they catch the eye of everyone around you.
Added:
Answering a big question that a lot of you are asking- Scheduled builds have not been impacted by top issues (for better or worse). If you have a build week, or even better a specific date, your rig will be built as ordered. Check your MIC top closely when you take delivery and make sure your desler logs any imperfections. I have faith that a fix will be on the way.
Q&A:
Thank you Ross for the update. Any insight on if its a design flaw or a manufacturer issue???
With all that I've been told (much of which I've shared with you, but certainly not all), the part is very difficult to manufacture under ideal conditions, and some of the final design designs - notably the raw exposed cut edges - are questionable.
That Webasto is an absolute dumpster fire (and that's insulting to campus parties down the street at THE Ohio State University) just took a small issue and turned it nuclear.
sliwa
Matthew
Ford Focus
Keep up the good work!! According to Ford customer service, I began build today at 11:10. Haven’t heard anything or been able to pull up a window sticker, so I guess I’ll believe it when I see it!
Azemotay
Logan
British Columbia
2021 4d Bronco
Appreciated as always with the updates.
Cridlon
CLIF
Boise Idaho
2009 Honda Civic
You're awesome Ross! I'm excited that my Big Bend, soft top, MT, no tow will be picked up for a build! 🤞🤞🤞🤞 at this point I'm actually happy I switched to a soft top!
Spooled
Republic of Texas
Raptor, Model 3
I got my fingers crossed hoping for an email this Thursday.
Ttp2017
Zachery
2021 Bronco Black Diamond
Do you know if they will favor producing more 2 door MIC tops in the capacity that they do have since that is our only option or are 2 door builds simply getting pushed back until the issues can be resolved?
Also we are so lucky to have you as a forum member! Thanks for everything you do and all the tedious questions you answer!
DUSTYcazOREGON
Craig
2022 Bronco Black Diamond & 2025 Yukon Denali. 2023 Mercedes Adventure Wagon.
Thank you for the updates!!!!
I have a 2 door ordered and with these roof issues....I am getting very disillusioned and concerned. I am a car perfectionist. I maintain my vehicles and keep them in an excellent condition. I will not settle for anything less than a perfect MIC top, especially on a $50K vehicle. WHY would FORD send these bad tops out to begin with? Are they going to do a better job of checking for these now known issues before they ever send a Bronco out to a Dealership? Now that these issues are known......we should see no more bad tops sent out......I would certainly hope so! It's been over a year and I really have no idea when I will get my Bronco....none. Despite Ford saying we would all have build dates by now. I passed up on a fully decked out Rubicon in a highly desired color last month....it's gone now (good for Ford!). At this rate..... the new Hummers may be out before I see my Bronco. Venting done but this quite frankly is getting old. I sure hope that FORD reads these comments!
Bronc-OH
New York
Jeep XK, Jeep WJ
Thanks for the update , glad to see that speed is ramping up.
Have you heard any news about the bronco sports? I have an order in RCM purgatory, sent a DM not sure you saw it or not.
DUSTYcazOREGON
Craig
Me too (2 door BD).....but lets hope they get the MIC issue resolved or we will be upset like others that have received bad tops.
UNBROKN
Central Virginia
04 F-350 CC dually, 97 Infiniti QX4, 21 Bronco BD
Ross, You are great to let people know as much info as you do. Some folks want to complain no matter what. If you have your Bronco, Shut up and enjoy it (not you Ross). Warranties fix issues like the top. Ford is going to eat a lot crow in the coming months until it is resolved.
Maybe they should steal a few people away from Bestop or the manufacturer of Jeep tops...
I will be excited to get mine in a couple months. Hoping I don't get delayed again, but I will be fine if it does. It only means Ford is doing their best to fix the problems as fast as they can and trying not to ship out a sub par product.
Glad you are enjoying your Bronco.
Headsong
Still wondering where all the Rangers go? In Chicagoland, I'm now up to MAYBE 3 dozen lifetime. This is a big area...and not many Rangers.
Sponticore
Justin
Toronto Ontario
My two feet
Thank you so much for the update.
The part that concerns me is the IF I'm lucky to get a hard top when I have no way of changing it now. Built status was June 22nd!
