powoq
Lux Sponsor (Level 2)
LA
go.powoqoffroad.com
Hey everyone,
If you actually use your Bronco for what it’s built for, keeping the inside clean is a constant battle. From throwing muddy gear and wet boots in the back, to hauling wet dogs or dealing with unexpected rainstorms with the top off, the factory carpet takes a beating fast.
We put together a TPE mat kit for the 2021-2026 Bronco 4-Door (except Sport). We focused on making sure everything fits flush and is easy to clean.
The entire setup is crafted from a waterproof, odor-free TPE material that handles spills easily. Beyond just being easy to hose off in minutes, this material is scratch-resistant, wear-resistant, and maintains great flexibility.
The floor mats are molded with raised edges to trap water and mud. The front row features secure clips to keep them locked in place.
In the cargo area, the backrest pieces use built-in Velcro to stay secure. They will not shift or fall off whether you are folding the seats down or pulling them back up. The whole rear area has a non-slip texture to prevent your gear from sliding around while driving.
Note: To ensure the cutouts align perfectly, please check your factory hooks against the orientation shown in our product photos before placing your order.
Check out the full setup here:
👉 Full Kit (Floor + Cargo + Backrest): https://bit.ly/yvrs6
Cargo Kit (Cargo + Backrest): https://bit.ly/jynrs
(Enjoy a 10% discount with code POWOQ10 for your first order!)
G1D1UP
J.
Gilbert, AZ
2024 Ford Bronco Raptor
"In the cargo area, the backrest pieces use built-in Velcro to stay secure."
This is the area that gives me the most aggravation! Do you have more detailed photos of the backrest velcro? The shitty back-of-seat rubber protectors I have on now always separate from the back of seat, near that damn hinge point. I'm always having to press that protector back down at the hinge point.
Do you "pinky-swear" that your product is better at this one particular area?
Matt-in-STL
Matt Armfield
St. Louis, MO
2026 Ford Bronco
Thoughts on whether these floor mats will fit my Bronco with the vinyl flooring? I know the front will with the snaps but the back seats don't have them with the vinyl flooring.
powoq
powoq
LA
go.powoqoffroad.com
I'm not sure how your current mats are designed around that hinge. We recommend letting the edge of the main cargo mat press down on the bottom edge of the gap cover piece to help keep it from shifting.
If it still doesn't hold secure, we will keep improving the design.
powoq
powoq
LA
go.powoqoffroad.com
Our rear floor mat doesn't rely on velcro or snaps to stay in place. The floor of our test Bronco is also a smooth surface.
Because the edges are precisely molded, combined with the weight of the TPE material, the rear mat stays firmly in its position and won't slide around.
Steve_In_29
St Johns, Arizona
2024 Heritage Limited, 2 Door, 1973 Bronco, 1999 Ranger, 2007 F350
How are these any different then the Lasfit, 3W, etc offerings that have been out for years?
You guys need to come up with something new or innovative and not just be another importer from the same Chinese factory.
Valhalla
Valhalla
Chattanooga Tn
Seat delete, headache gone...
Valhalla
Valhalla
Chattanooga Tn
3W gets my vote! (but they gave me mine to try, I prefer them over the stock mats because they clean easier.)
powoq
powoq
LA
go.powoqoffroad.com
Any chance you can make some in hot pink for me ?
We actually have some pink accessories in development. I’ll pass your request along to our team for consideration.
