Camburg Long-Travel Lower Arms
Camburg
Camburg
Huntington Beach
2020 Ford Bronco
Ready to upgrade your Ford Bronco suspension? We went 2” wider per side in order to gain wheel travel, articulation and stability. Utilizing the OEM or aftermarket fenders, you’re able to run up to a 37″ tire without limiting wheel travel or turning radius. The kit is designed to use readily available bolt-in OEM style aftermarket 2.5/3.0 coilovers. So, if you want to build it up in stages or if have already lifted your Bronco with coilovers, you can use them with this kit. We recommend extended travel coilovers for maximum useable wheel travel.
Camburg Trail Series Long-Travel Kit
Ford Bronco / Bronco Raptor Suspension Systems
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
I hit your customer service up in January of 2024 about the kit. Now I am no longer interested in being the first one. The kit looks nice but I have absolutely no clue if it would hold up to years of abuse. Go take that pretty bronco through some rock gardens and test those lower control arms. I am about a year out from a front end rebuild, you get someone proving the kit now, I might be a customer.
