Say Goodbye to Clutter: PTYYDS Multi-Functional Overhead Molle Panel
ptyyds
Lux Sponsor (Level 2)
Alex
Hi Bronco fam!
Imagine being on a desert trek or forest camping trip, only to find the tool you need most buried at the bottom. This Overhead Molle Panel for 2021–2025 Ford Bronco 4-door models is designed to break this storage dilemma. Please note that it is not compatible with Bronco Sport or Raptor.
The design transforms the roof area into a multi-functional storage zone. The upper surface can hold travel bags and fire extinguishers, while the Molle grid underneath is ideal for mounting other frequently used gear like interphones and hooks. The metallic surface supports magnetic lights for additional interior illumination. The crossbars also serve as grab handles for rear passengers, providing support during off-road travel.
The main structure is made of carbon steel and aluminum alloy, providing structural strength and resistance to rust and wear. Compared to nylon products, the metallic material maintains stability and solid load-bearing capacity over long-term use. Additionally, the kit uses a bolt-on design that requires no drilling into the vehicle body.
Learn more through the link below: https://www.amazon.com/dp/B0GLYXKQTW
Sparkie
Massachusetts
Sold all my cars to buy the Heritage Bronco
Hi Bronco fam!
Let us know when you have a model for the 2 door Bronco.
broncdawg
Bill
2025 Ford Bronco
By less refined do you mean less expensive? Because it's definitely that.
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
Sorry, I didn't look at the price!
The DV8 appears to have slightly softer bends and angles, larger squares for the molle panels and generally a bit more refined...
ptyyds
ptyyds
Alex
I’ll share this with our team and update if there’s any news!
Ninjak
Miami
Definitely out of the DV8 playbook. I have the DV8. Lol, I am wondering what they did to be able to bring this to market.
