Marie_ARB
Marie
Maple Valley, WA
Toyota 4Runner
Ford Bronco ARB Zenith Bumpers on Sale BRONCO_BUMPER_3
Our Zenith bumpers are now on sale, and we bet you’ve never seen savings like this before!
Never seen our Zenith Bumpers? Here’s a quick overview of what you can expect.
What you're getting with our Front Bumpers:
Ford Bronco ARB Zenith Bumpers on Sale BRONCO_BUMPER_1
  • Built tough – Heavy-duty steel construction with a zinc-rich primer underneath and a durable Integrit black textured powder coat on top. This thing is built to take a hit and resist rust.
  • Drop-in replacement – Designed specifically for the Bronco wide fender flares, so it bolts right on without any cutting or fabricating.
  • Keep your factory tech working – Your adaptive cruise control, parking sensors, and fog lights all stay fully functional. And the bumper comes pre-fitted with housings that accept your OE LED fog lights, so no need to buy new ones, though with the savings from this sale, you definitely could!
  • Integrated LED light bar – Comes with a light bar already built in, so you're not hunting for a mount or running extra brackets.
  • Recovery ready – Includes two forged, chassis-mounted 8-ton rated recovery points. These are the anchor points used when you need to get pulled out on the trail. And they’re properly rated, so you know they won't let you down.
  • Jack points – Two dedicated jack points are built into the center so you can safely lift the front of the truck on the trail without improvising.
  • Big tire clearance – The wing design is shaped to clear up to 37" tires with the right lift and wheel offset.
What you're getting with our Rear Bumpers:
Ford Bronco ARB Zenith Bumpers on Sale BRONCO_BUMPER_2
  • Same tough build – Steel construction, zinc-rich primer, Integrit black textured powder coat, matching the front. You know the deal, it will hold up through anything.
  • Keep everything factory – Your OE tow bar and wiring stay completely intact, and it's fully compatible with your rear parking sensors. No cutting, no rewiring.
  • Jack points – Two more jack points built into the outer wings, to pair with a jack.
  • License plate sorted – The plate relocates to the spare wheel, and an LED license plate light is included in the kit so you're road legal right out of the box.
  • Clean look – Features a vintage silver center panel that neatly houses the tow bar and rear sensors.
If you’ve been planning to upgrade both ends of your Bronco and add some new bumpers, the bundle is the way to go. Drop any questions below, we're happy to help!
SPS573
Oscar
Las Vegas
Does this have a winch mount?
Do you need to buy the “mounting kit”?
Thanks!
cvhookem63
Caleb
ETX
Are only the wide flare versions on sale? Any chance the narrow flare versions are discounted as well? In the market for these.
Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
need a sale on the summit winch bumper!
RustysBronco
Matt "Rusty" R.
Jupiter, FL
www.instagram.com
2022 Ford Bronco Badlands Sasquatch
@mariedubray is ARB going to ever release their suite of remote reservoir coilovers to the Bronco community? They seemed to show up in beta phase in 2023 then suddenly fell off the radar.
Steve o
Steven
North of Boston
Outer Banks '24, 2.3L v6, Auto, HardTop.
Does this bundle kit come with the light bar or is that an add-on? Your website doesn't show what the non-winch style looks like. Can you post that?
A local reseller of your products doesnt have any of this in-stock; Order thru you or thru the reseller?
Wolfhound
PNW
86 Samurai tintop, Solstice GXP Clubsport, Transit 350
I’m sure it’s a quality product, but a little to jeep angry bird for me.
F-Spot
SoCal
Tesla, FJ
Don’t know if you navigated away from the links by the OP, but all details are on the OP’s post and in the links. The pic in the first post is the non-winch Zenith bumper and as stated, does include the light bar. I’m going to assume this is a clearance directly through ARB, do you will most likely need to order through them.
derichio02
Bo
Southern California
Bronco Badlands, Maverick, Tesla M3, F250 Tremor
The link in the first post is for the narrow front bumper as per the &A on their site
"The 3280010 is 70 inches across. The 3280020 is 72 inches across. A total of 2 inches wider."
But the description contradicts this so...
cvhookem63
Caleb
ETX
I have been researching these bumpers for a while. Everywhere else including their website lists the 3280010B as the wide flare model and 3280020B as the narrow flare model. I would assume the reply in the Q&A was mixed up rather than all the documentation from their site and retailer sites being wrong.
cjetcat
Dan
Des mointes, Iowa
Cougar Eliminator
I thought that I got a good Black Friday 2025 deal at 699.95 each. Did not know there was such a thing as a bundle deal. :sadface:
The install was time consuming but I love their strength and looks.
Rear bumper gaps look good on black Bronco.
Ford Bronco ARB Zenith Bumpers on Sale 1000030467
Ford Bronco ARB Zenith Bumpers on Sale 1000030452
