2021+ Ford Bronco OEM LED Reflector Headlights w/ Signature Halo Upgrade
infotainment
Lux Sponsor (Level 2)
Oviedo, FL
2022 Ford Bronco
Hey Bronco Owners,
If your 2021+ Ford Bronco came with the standard reflector headlights, you’ve probably noticed the difference compared to the higher trims that feature the signature halo LED lighting. That distinctive LED ring instantly changes the look of the Bronco’s front end and is one of the most recognizable lighting designs on the newer models.
The good news is you can upgrade to the factory LED Reflector Headlights with Signature Halo with the same OEM lights found on trims like the Outer Banks, Badlands, Wildtrak, Everglades, and Heritage Limited. This upgrade replaces your factory headlights with genuine OEM units designed specifically for the Bronco, giving your SUV a more aggressive look along with improved nighttime visibility.
What This Upgrade Adds
Signature Halo LED Design
The most noticeable feature is the LED halo ring surrounding the headlight, creating the signature Bronco lighting appearance.
It gives the front end a more modern and premium look while still keeping the rugged design the Bronco is known for.
Improved Night Visibility
These OEM LED headlights provide brighter and more efficient lighting compared to the base reflector lights.
Whether you're on dark back roads or off-road trails, the upgraded illumination improves visibility and driver confidence.
100% OEM Components
Unlike many aftermarket lighting kits, this upgrade uses genuine Ford OEM headlights designed specifically for the Bronco platform.
That means:
  • Factory fitment
  • Factory connectors
  • No splicing or custom wiring
  • Seamless integration with the vehicle
Installation Overview
Installation is rated 2 out of 5 in difficulty, making it a very manageable upgrade for most DIYers.
The signature halo LEDs give the Bronco a much more aggressive and premium front-end appearance, similar to the higher trim models. At night, the brighter LED output also improves visibility while maintaining the factory lighting style. For many owners, it’s one of the easiest ways to upgrade the look of the Bronco while keeping everything OEM and factory correct.
💸 Forum Exclusive
Members get 15% off this upgrade with code bronco6g15
💬 Have Questions?
Our U.S.-based team is ready to help:
📞 Call: 1-855-636-6287
📧 Email: [email protected]
💬 Live Chat: available on our website during business hours
Warhorn
Everglades
Wisconsin
2024 Bronco Everglades
Everglades
For $3300 you would think they would at least have matching headlights across their two photos…
DubZuc
Zuc
Tampa
‘21 2 Door Base & ‘23 4 Door Basequatch
$3300? You can't be serious!
FourHorses
Four Ford Horses and an Expedition
Come on, they really are only $2804.96!
Maybe code bronco6g85 will work. Lol
BroncocnorB
Paul
Clearwater Beach
1965 Cobra,
I’ll sell you my headlights for $2700. Taillights another $1000. My auto theft deductible is $250 so everyone wins
24GTBadlands
IL
24 Badlands v6, 24 S650 with PP GT
1200 per side on Rock Auto (limited availability)
