dougcjohn
Doug
Iowa
‘24 F450 Limited, ‘25 Bronco Raptor, ‘16 Smart Fortwo, ZX12R
I purchased the Bronco Tool Kit,
Used the REDEEM226 and received a $52 discount on Tool set.
I don't know the accuracy of the other 2, but the REDEEM226 worked without issue today: Thursday, Feb 19 2026
  • WINTER2026: 20% Off Floor Mats and Liners.
  • Redeem226: 15% Off Accessories (maximum $150 savings).
  • BRONCO20: 20% off select Bronco/Bronco Sport accessories.
https://www.ford.com/cl/accessories
GoHawks63
George
Metro Detroit
2024 Bronco Wildtrak, Cadillac CTS-V Coupe, Roush Stage 3 Mustang convertible
Thats the code I used when I purchased mine a couple weeks ago. The $52 discount was the motivator for me pulling the trigger.
dougcjohn
Doug
Iowa
I went back to get some Ford Fender covers. But they’re out of stock.
May search for the security parameter alarm module & light. Those are quick to install & setup.
dougcjohn
Doug
Iowa
If anyone is interested... The Parameter security module takes the 15% discount too.
Pasted a screen shot if you wanted the Part Numbers.
Only irritation is the LED Wire, comes with a Dealer Install requirement... that charges you up front $70 that you have to later back out at the Dealership when you pick up wire. The Security Module they send direct to your home, no installation required... go figure.
Ford Bronco Ford Accessory Discount Codes - Feb 2026 FullSizeRender
Bronco Naughty Pines
Jerry
Scottsdale AZ
2022 Bronco
You guys are lucky you can use any codes, living in Arizona we're black listed, and a couple other states. That's totally BS.
dougcjohn
Doug
Iowa
Interesting, even a Ford website with its own discount codes? I would think if you can reach and navigate within the Ford Website, you could enter a code inside the Website. A content blocker wouldn’t block it.
Or are you saying State Govt or actual Websites are blocking AZ Residents (Az IP Domains) from accessing Websites?
Interesting, hadn’t heard that before.
Get a VPN client and use an IP outside of AZ. Unless they’re blocking mailing addresses too.
Jerry
Scottsdale AZ
2022 Bronco
I've tried a couple of times. It's a state thing. Thanks for the code, I'll try that
Ford Bronco Ford Accessory Discount Codes - Feb 2026 Screenshot_20260222_120542_Outlook
dougcjohn
Doug
Iowa
Wow! That is a State block… 3 states.
Very interesting, and I wonder why?
They get their State taxes, don’t see why the block.
Feel for ya!
OBX_SAS_2021
Charlie
When I bought my Ford performance sids here in AZ the dealer near my house wouldn't let me use any discount codes and said I don't get any points unless I have them do the install. Needless to say I did the install myself. I just purchased the ProCal tune from Tire Rack and it was cheaper than Ford site with discount code.
Rough Rider
2018 Mustang Convertible
its a dealer franchise law thing..... in those states....
